Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 11-05-2023 at 08:27 AM.. |
If he's unsure which mixture is adjusted it's alwas a good idea to check it before making any changes. So you can conclude if the engine is in right condition. Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
On my 3.2 with the CAT delete the throttle response was amazing and the sound... perfect with the stock muffler... but the fumes at stop lights in LA were not worth it for me and the wife or any other co-pilot... Now I run the stock Cat and a Fabspeed Supercup and couldn't be happier... still a little less responsive from a stop, but checks all the boxes and I can idle easy without the smell of fumes. Be safe, Have Fun |
911 3,2 burns very clean....i even passed the smog once with the strait pipe in LA, but back in 2008... Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Using the sweet 91 octane w 15% ethanol that we get as CA citizens.
All I can say is my 3.2 has a smell that I don't like... so having a Cat is worth the benefit of an absolutely smell free cruise. My car's fully in tune now, but I'll be running the Cat life personally. -Ian |
try to get toluene at the paint shop that will give the octanes you need.1/2 a gallon per half a tank..that is a sweet sauce..i used it all the time in CA
Ivan
Targa_PB_78_SC
BareRearedRookie |
R&D guy
Location: the border between the states of inebriation & confusion
I find the comments about smell interesting and certainly contrary to my experience. But then, in my area 93 octane is readily available and gasoline is a maximum of 10% ethanol, unlike the above-referenced 15%.
In my '87 3.2 I am also not running a Fabspeed bypass pipe but am instead running a Fabspeed euro premuffler. Unfortunately, people are not always careful to distinguish these when referencing cat substitutes. I've run this with the stock-style muffler and with a Dansk 1-in-2-out (84mm). The Dansk 2-out is a bit loud for highway driving so I switch mufflers depending on how I am using the car. The Fabspeed euro-type premuffler has the bung for the OEM sensor and no re-tuning was needed, but I do have an SW chip (93 octane low-restriction exhaust version) in the ECU. And because the premuffler gets hot and removal of the cat also meant removal of the heat shields, I wrapped the Fabspeed unit, like I used to do to muscle car headers back in the day. |
Crotchety Old Bastard
Smelly exhaust after swapping out a cat for a bypass pipe is often due to the engine being in a less than optimal state of tune. The cat will cover up a rich condition that would normally be looked after if no cat were present.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Replaced my cat with M&K pre muffler and muffler. Great quality and sound. Very pleased.
This on the '88 3.2.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Thread Tools | |
Rate This Thread | |
