911 sc power window issue
Took a quick drive in the SC tonight and “rolled” down my passenger power window only to have it not come back up. Just replaced the driver side/passenger window switch recently and have not had issues with the passenger side switch before. When I’ve had this issue in the past it normally comes down to the switch, but in this case neither works. Any ideas? Thanks.
1979 911SC
1978 911SC Euro
Instagram: collierbrands
Old 10-11-2019, 05:48 PM
echecsqueen's Avatar
Fuse? Is the motor actuating?
Sent from my BBB100-1 using Tapatalk
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 10-11-2019, 06:08 PM
Josh D's Avatar
I’ve had to replace both pass and driver motors in mine. Spur gear in the transmission strips teeth.
You could try operating switch while pulling glass up to see if it catches, providing this is your problem.
Replacement motors are reasonably priced, but they’re a little bit of a pain to replace.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 10-11-2019, 07:02 PM
--The passenger side motor on my '88 acts up every once in a while. I get it going by banging the door card where the motor is or slamming the door while holding the switch in an on position. Just balky, I guess. Should take it apart and clean and lubricate it but I'm too lazy since my "fix" works for me.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 10-11-2019, 07:21 PM
Your relay at the front fuse box might have gone bad too. Switch it out with one of the other round black relays and see if they come back to life.
Old 10-14-2019, 08:24 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Print/cut & paste.
Not certain the color codes will match up with your model/year.
pm me as needed.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-14-2019, 08:54 PM
