Engine failure while driving
My 1987 3.2 Carrera just had to be towed. It drove perfectly this whole weekend including city and highway driving. Today, I decided to take the highway and just after entering the highway things went badly. The car started to “stutter” when I accelerated. I changed from 4th to 5th gear, but the same “stutter” occurred. The oil warning light and the battery light lit up (maybe other ones as well but I might have missed them as I was somehow stressed). Therefore, I drove to the side of the highway and turned off the car. When I tried to turn it on again, it would not start.
Hopefully, nothing major. I had them tow it to a local air cooled specialist. Hopefully, nothing major. I will know more the next couple od days but does anybody have an idea what happened? Thanks, Boris ![]() |
I'm good with tools.
Sounds like a bad DME relay.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 02 996 4S (owned since new - heavily optioned) |
911 enthusiast
Same thing happened to me. Had to get flatbedded back home. It was the DME. I don't leave home without a spare anymore.
Grappler
Sounds like a classic DME relay failure. If it turns out to be the case pick up the redesigned Solid State type and you wont have to deal with this again. Otherwise as others have said, keep a spare.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Can anyone confirm that when the DME relay goes bad, the oil and battery lights come on ?
1986 Bosch Icon Wipers coupe. |
Grappler
Its not that a failed relay triggers the lights, rather the engine stalls and since the key is still in run position, the lights come on.
Dear all,
Thanks a lot. That is reassuring. I just purchased the car in April so that I am quite new to the vintage car experience. Actually, I had a spare DME relay with me after a friend had recommended to always have an extra one in the car. Unfortunately, I was not aware that this was the issue. But also, I guess it would not have been safe as the highway was quite busy at the time (the pic does not reflect that). Thanks, Boris |
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Spiderman
When my relay failed 3 years ago the car simply quit running and I coasted into a side road. After a short period of reflection, I remembered the tattered box in the glove compartment and gave it a try, no tools required. Fired immediately and got back to the in-laws where I fastened it down correctly and ordered another for the same tattered box. I had no sputter or prolonged failure but no idea what the different ways it can fail are.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
DME Relay.
Yup!
Keep a spare in the glove box! Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
When my original, installed by the factory DME relay failed is was intermittent. Just driving along it would stutter for a second, and then clear up. I swapped it, and all was fine for many years.
I have the sold state one in the car now, but I still carry a spare DME relay and once I was the magic man when a friend at a Porsche event has his DME relay fail. I just happened to have the spare he needed. Sometime they just die and the car will not run at all. Sometimes they just partially fail, and the weird symptoms start.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Rescuer of old cars
The DME relay has 2 functions — it powers the fuel pump and also the ignition. If the ignition side fails, the car just dies. If the fuel pump side fails, the car sputters as it runs out of fuel.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
I freaking love the previous owner of my car. Reading this thread and I'm thinking...this sounds familiar. Double checked...and sure enough...spare DME Relay in the glovebox. Awesome.
Current: 1984 911 Targa Whale Tail "Gemma" 2014 Boxster S (wife) "Sir Jenson" (She named it...not me) Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4 |
Also keep a 10mm wrench, otherwise, your spare DME will stay in the glovebox!
LOL...I will check. The full OEM toolkit is in the frunk...but I don't know if there is a 10mm wrench included. Thanks!
Yes, the Carrera has a 10 x 11 mm double open ended wrench, 999-195-012-02, in the tool kit. Though it may have gone MIA over the years.
I'm good! I just pulled the toolkit out (it's still has the original plastic bag it was shipped in) and checked. It's got the 10mm + what looks like everything else. Even the belt. LOL. Again...amazing previous owners.
Diss Member
A spare DME relay is nice but as an "emergency piece" I keep a DME jumper in the car. Because it is simply 3 connectors hooked together with wire you can visually see that it is correct and with any DME relay you would always have a question what is happening inside the box.
![]() You just crimp some wire between three .157" male bullet connectors. Dirt cheap and pretty impossible to fail. The 3 sockets you need to connect are #30, #87, and #87b. (I have the numbers on labels on the leads so I don't have to remember.) MAKE SURE YOU PULL THE JUMPER WHEN YOU TURN THE CAR OFF!
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Dear all,
Thanks so much for all your input. This community is truly outstanding. Just to give you all a brief update, the problem was indeed the DME relay. Thanks again, Boris |
