What to use to keeps mats in place
My driver mat shifts forward on my carpeting in spite of having a thousand plastic spikes on the bottom. What do you use to keep your mat in place?
Jason
'79 911SC Targa
Old 11-09-2019, 12:35 PM
Lloyd Mats have straps to attach to the seat rails.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 11-09-2019, 12:44 PM
Jason,
I had mats like those with the thousand spikes on them - they ruined my carpeting in no time.
I still don't know how to keep the front mats and carpet in place - the straps to the seat rails don't work very well for me.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 11-09-2019, 01:39 PM
964TargaC2's Avatar
I use zip ties,
I think that maybe I'm dreaming..
Old 11-09-2019, 03:26 PM
walt's Avatar
I have lloyd mats and I use the supplied straps attached under the seat. I also found it necessary to use a large binder clip on the door side to clip the mat to the carpet. Doesn't look all that great but it works.
Walt
82SC 3.0
81SC 3.6
Old 11-09-2019, 05:20 PM
Originally Posted by 964TargaC2 View Post
I use zip ties,
I've owned my car for 18 years. It's been on my list to figure out the size of the female clips on the bottom of my overmat, and buy corresponding male clips, then strap them to the seat supports, for about 17.9 years.
I will use zip ties.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 11-09-2019, 05:23 PM
Twisted safety wire through the mat, back to the seat rail might be fairly invisible. Or a straight section of black coat hanger bent to a hook on each end.
Old 11-09-2019, 07:22 PM
2 piece Velcro Sticky Back to the floorboard is what I use after getting tired of replacing zip ties each time I vacuumed under the carpets especially around the pedal cluster. Zero movement.
Old 11-09-2019, 09:12 PM
Velcro seems to work well in all BMW,s
Old 11-10-2019, 06:20 AM
I'm using a velcro also and it keeps my mats in place.
Old 11-10-2019, 11:33 PM
AndreasK's Avatar
+1 on the velcro.
1977 911s
Old 11-11-2019, 04:09 AM
Thread Killer
Teutonics's Avatar
Same here (although 17 years)...
Just this summer I finally cut the loops open and bought new clip sets and strap off of amazon... there's enough strap left (if you cut only one side at the attachment/sewn point) to use with the new adjustable clip set. Then run the new strap in a loop around the seat mounts to the other side of the clip.
I think the total cost was around $10....should have done it years ago.
Edit: Total was $6: https://www.amazon.com/gp/product/B078P3GMWV
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 11-11-2019, 05:18 AM
