Blown air box on start up !!! Help Please
Just tried to start my 1976 2.7 911, was running ok when taken out 4 years ago, put new set of plugs in, adjusted tappets, set points.....
Primed fuel system by lifting airflow lever in air box Turned key fired up first revolution ran nice for about 2-3 seconds the stopped, did this a few times, so decided to give it a little remote throttle (next to the handbrake), tried starting again and BANG backfire, air box has visible cracks in it and screws popped off... Any ideas what could have gone wrong ?, could not having filter & cover on air box cause it ? or can you over prime using the air flow lever ? or remote throttle ? Not a great day ![]() Any good How to threads re replacing air box ? |
Same thing happened to me...it's a good time to reseal everything from the intakes up. There was one for sale yesterday here https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1043078-cis-airbox.html ,and yes there are several write ups on how to proceed on this site....will have to look for them:<)
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Designer King
Not having the cover or filter probably didn't cause it. I don't know where you are located, but if you're in one of the many areas in this current unusually early cold snap, the cold air might be a part of it. Your cold control pressure may be too high, causing a too lean mixture @ low temps. Resetting your points may have changed your timing slightly, as well. Also, your WUR may be a little out of spec, which wasn't apparent when you put the car away.
You might want to consider a popoff valve in your new airbox. I know it's a "belt and suspenders" solution, but I like the added security for those "just in case" situations. If you do a search, you'll probably find some info on airbox replacement. There may be something in the "How To" section or Wayne's book.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
I have CIS also although i do have a 3.0 litre ..
i NEVER " prime the fuel lines lifting air plate .. " you are dumping raw fuel into the intake runners when you do this. this will just pool in there and vapourize and then bang.. i store mine all winter .. even when restarting, i just fire her up and never have a problem .. if i want to prime the lines i remove them from the injectors first and put them into gerbers baby food jars or something similar. the good news is with the new airbox it has a plenum insider it to help distribute fuel . although i think its connected to the CSV and i dont think you have it if you have the hand throttle. i think the CSV and thermo time switch replaced this. I personally am not a fan of the pop off valve. Even when i replaced my air box ( for an unrelated reason ) i never pout a pop off valve in the new one and it has been fine for over 12 years.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
I don't know if this really helps but when my 79SC sits for a few weeks to months I prime the fuel system but not the engine.
I use a fuel pump relay with a toggle switch installed to run the fuel pump. When the fuel pump is manually turned on you can hear the pump strain when it "charges" the fuel system from the tank to the fuel filter. This way I think the fuel fed to the engine helps a more even regulated pressure so a no temporary lean condition exits. Before I started doing this I would get a few scary pops thru the intake. Does this make sense? I already had the relay/toggle switch for CIS tuning/testing/repair. Terry
79 SC Minerva Blue ROW Non Sunroof Crank Window Coupe 3.0 SSIs, Backdated Heat COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires |
air box
If you have trouble finding an air box, let me know.
Dan Petchel CarsincNJ.com Targa top Restoration Vintage parts 609 298 2277 carsinc@comcast.net |
Down the fault tree farther is the possibility of a sticking fuel injector
1980 911 - Metzger 3.6L 2016 Cayman S |
Thanks everybody, just got engine out of car, just need a good how to!?
I think this goes with out saying but you should seriously consider a pop off valve in your new air box. Mine has saved me at least a few times. Our host carries them and has a great walk through on how to install them.
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
Would excess fuel still be in the intake runners if the engine had run a couple of times for 2 - 3 seconds? I still can't find a How to, anybody !? Cheers Mark UK. |
Still here
Lots of info here.
https://forums.pelicanparts.com/porsche-911-technical-forum/758788-cis-troubleshooting-dummies.html stlrj already posted the relevant thread. https://forums.pelicanparts.com/porsche-911-technical-forum/689763-blown-airbox-replace-prevent-while-im-there.html#post6865184 is what you need. |
Lots of great stuff in the threads and will be very useful but no How To.
Eva
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
ROW '78 911 Targa
That 82 airbox has the same size ports as 74-77 and 80-83 US.
Only 78/79 US had bigger ports in the US.
I followed this advice on a different thread !
Diagnosis so far from this Forum and local specialist here in UK, say the reason for my blow air box is because I followed the advice quoted above. Priming this way you are in danger of putting large unknown quantities of fuel in to your intake runners, give the right conditions on cranking BANG. |
Wildman Emeritus
Feel your airbox pain. Mine blew on initial startup after a drop and trans rebuild several years ago. I was so p*ssed off that I had it flatbedded to a local shop and let them replace it. New pop off valve installed and no more issues other than a feeling of lightness in my wallet.
FWIW, all sleeves and seals were installed in the intake system and it already had a pop off valve that I had installed. Supposition is that I had a slight leak somewhere. Upside is that you will have a shiny new airbox and not an old, brittle one
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Believe it or not, the factory did come up with a solution...the 3.2 Carrera. Unfortunately, starting a CIS engine will always remain a game of russian roulette, turn the key and hold your breath.
Cheers, Joe 87 Carrera (solved it for me) |
Are you looking for a how to replace the air box? It is really very simple and can even be done with the engine in the car and a partial drop. If you have the engine out and have the parts it should not take longer than an afternoon.
I've done it several times with the engine in the car but never made a DIY. Lots of guys here will help walk you through it plus you should have a Bently manual
1982 SC |
