Fuchs 15inch brake options
Hi all,
I know that this topic has been discussed ad nausea. But I cant find a true solution. I currently have non boosted brakes, with 3.2 calipers on with a motor pumping 300hp on 15inch ****s which I use on tarmac rallies. This car does not stop where I want it to, and any attempt to try brake where I should, results in the car to keep going in a straight line, then I have to dump it into engine brake and get in a spin to stop. This is done not to run over people/marshalls. hehe. Ive been reading the forum and people have mentioned using boxster calipers. However lets say budget is no problem, I literally need the ultimate, a google search isn't pointing me in the right direction. So please, name or pm vendors, and if I should maybe install a brake booster (again name or pm vendors) He who can supply a whole package get my monies. Im fed up of not stopping and being the gift that keeps on giving. ![]() Much love |
I would rather be driving
930 brake calipers F/R. rear calipers need to be modified for 3" mounting holes on your trailing arms.
930 rotors front and rear with proper rotor hats on the front. 23mm MC to supply enough fluid for the extra pistons in your new brakes. Done. Boxster brakes will increase braking torque due to larger pads but uses the same rotors as the 3.2 Carrera brakes you currently have. There is no increase in thermal capacity. I want to know why you can't stop short enough. Is this brake compound? Pad grip? overheating? wheel lockup? single wheel lockup? The 3.2 brakes up front are usually very good. I tracked a set of a long time without any issues. Just needed proper pads and some cooling ducts.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Its actually not a heating issue, its more a cold bite issue our stages are like time trials 50-70seconds long and we don't get enough heat in the brakes.
I use Ferrodo DS2500, which have the best cold bite. so I actually need more "clamping" power, the lack of heat is my biggest enemy. Thanks |
I like the Ferrodo DS2500. They are on both my cars. But they need a little heat to work best.
What other pads have you experimented with? How much does the car weigh? What wheel/tire setup are you running?
Sounds like your application is more like an autocross than a racetrack. This will be an interesting discussion because most of brake upgrades (930, Stoptech, Brembo, etc) are designed to increase the thermal capacity of the system so it doesn't overheat. I agree with jpnovak, while they aren't sexy the stock Carrera brakes are very capable with good pads and fluid. You could size down to SC or mid year brakes, which are the same diameter but thinner than the Carrera parts so they'll heat up a little sooner. If you want more initial bite or grab adding the power booster would help, you may lose some sensitivity and modulation.
agree with the booster comment -- even cold, standing on my (boosted) Carrera brake pedal will lock up wheels --
No i haven't experimented with other pads, cause from my other cars i would not change ferrodo. Last edited by Chassis87; 01-14-2020 at 11:28 AM.. |
Any idea from where i can get me a power booster? |
Are 930 calipers bigger then 3.2 calipers?
Isnt there an aftermarket for brake kits under 15 inch like wilwood, ap, or the other major players. Thanks |
930s originally shipped standard with 15x7 / 15x8 Fuchs, so while the 930 calipers are bigger, they were designed/intended to fit under 15" fuchs.
That said, seems a boosted MC is likely the best solution for your issue |
Front brake torque @70bar line pressure for
A or S 1444n-m Boxster on C3.2 rotor 1815n-m 930 1961 n-m You get the most bang for the led effort from 930s You do want to do both for and rear for bias and use a 23.8mm m/c for the best pedal There are calipers that give you more like 993RS @ 2306n-m but they won't fit under 15s The limiting mechanism is the tires, any of the above are capable of locking the tires especially if used artlessly
Bill |
Do I also need to change discs, or can I use the one's I have? Thanks |
a pile of parts ![]() front ![]() assembled front ![]() original rear is trailing 3.5" mounts which need to be machined for leading 3" front mount on a 911 ![]() stock rear bottom, modified rear top ![]() additionally if you buy '87 up rears the fluid intake will need to be modified ![]() ![]() for a non boosted car you need an ATE ports left m/s It's best to buy a kit which includes the m/c actuating rod anfluid feed lines and fittings ![]() ![]()
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 01-14-2020 at 02:26 PM.. |
Still think you only need a boosted MC -- If I got in my '86 Carrera now, immediately drove it to 30mph and slammed on the (still stone cold) brakes, I'd lock up my front wheels immediately and be backing off to modulate. You should be able to do exactly the same thing with stock calipers/disks -and your limitation appears to be stemming from a lack of vacuum assist. While 930 calipers and a 930=compatible master cylinder will get you to the same place, the primary benefit of 930 calipers and disks (yes, yo will need to change disks too -- this gets $$$$) is fade resistance.
Recommending a specific MC for your application and retrofitting vacuum assist to your early SWB car is beyond my (very limited) scope of knowledge -- but others should be able to easily chime in -- and get your desired result (increased stopping power, not increased fade resistance) for a lot less $$$$ than a 930 brake retrofit |
Was reading a post on how to do...seems complex for my knowledge too. |
