testing for a current draw with 2 batteries
I'm pretty certain I have a current draw on my '69E, but to be certain, I want to know if it matters which battery you work from? It doesn't seem like it would, but i wanted to check. thanx. steve
Old 11-23-2019, 09:28 AM
proporsche's Avatar
hi Steve ,no,it does not matter where you check...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-23-2019, 09:36 AM
thanx so much, Ivan. s
Steve Meltzer
'69 911E/bastard
Old 11-23-2019, 10:04 AM
You need to disconnect the other battery if you're going to check for current draw.
Old 11-23-2019, 10:18 AM
IOW, just use one battery source (B) for the parasitic current draw tests. Deactivate by disconnecting the ground cable on the non-test battery (A). Perform the test on the active battery (B).
Connect an ammeter in series with its ground cable (B) to measure parasitic current.
Sherwood
Old 11-23-2019, 11:36 AM
OK, thanx guys, i had no idea, so i'm glad I asked! I've done this test before, but not on a two battery system.
Steve Meltzer
'69 911E/bastard
Old 11-24-2019, 07:16 AM
can someone explain the science and reasoning for dc'ing the non-test battery? thanx s
Steve Meltzer
'69 911E/bastard
Old 11-24-2019, 01:26 PM
HarryD's Avatar
Picture worth 1000 words.
Wiring is like this.
Ground Connection -|--BATTERY 1 (Driver Side) ++++|+++LOADS
Ground Connection -|--BATTERY 2 (Passenger side)+|^
you have 2 separate ground connections. If you only measure at one, you will have current flow at the second as well.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-24-2019, 02:18 PM
OK, i got it. thanx so much. s
Steve Meltzer
'69 911E/bastard
Old 11-24-2019, 02:43 PM
