What is this small light used for?
I was replacing my floor carpeting today and I found this small light under the carpet between the parking brake lever and the shifter, what is this light used for? is it even a factory installed item?
Old 11-17-2019, 03:08 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Light.
I think it is a light for your heater levers.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-17-2019, 03:20 PM
Gerry
it's covered by one of these https://www.pelicanparts.com/More_Info/91463210700OEM.htm?pn=914-632-107-00-OEM&bt=Y&fs=0&SVSVSI=
Old 11-17-2019, 03:33 PM
So is its for the rear glass defroster? Then what is the pull switch on the dash is used for??
Old 11-17-2019, 03:51 PM
No, 'defrost' refers to sending hot air to the upper registers to defrost the windshield and door glass.
'80 SC Targa
Avondale, Chicago, IL
Old 11-17-2019, 03:56 PM
right! it's reminding that you need to lift the levers (and do the following with your dashboard "climate control" levers -- turn off the outside vent air and move the red lever to the up arrow) to activate defrost
It must have been required by some sort of regulation
Old 11-17-2019, 04:03 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
and its supposed to be installed on top of the carpet, not underneath!! lol..
Marc
Old 11-17-2019, 06:25 PM
That's fond- just deglaze
The actual markings for the illuminated cover are pretty unique (Part #914-632-107-00).
It's very Doug DeMuro, "quirks and features"...
Missed Approach
Petra- 1986 Coupe
Old 11-17-2019, 07:21 PM
It is a the exact same part used in the 914.
I bought my 914 new back in 1974. Before I sold it, I swapped that cover for the identical one in my 911. So I have had that one part in my car since 1974.
It is just a light to let you know how to adjust the heat. 100% useless once you know how to operate the heaters. The government required it to be added way back then.
Old 11-18-2019, 07:26 AM
I'm good with tools.
AG81's Avatar
Definitely needs to be on top of the carpet......but if you don't need the reminder leave it where it is........
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 11-18-2019, 09:27 AM
theiceman's Avatar
does anyone else think thats backwards ??? what am i missing ? you pull up on the levers to route the hot air in from the exchangers .. how does pushing levers down blocking the heating from getting into the cabin help defrosting ??
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-18-2019, 09:37 AM
scumbag
Think 'back and forth' instead of up and down.
pull the levers back (up) for heat.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 11-18-2019, 09:41 AM
theiceman's Avatar
right !!! .. damn Germans .....
Old 11-18-2019, 10:03 AM
Analog Air Cooled
Hotshot's Avatar
Hey another light I have to change. Does it come on with the normal lights?
Old 11-18-2019, 10:22 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Comes on when the defrost is engaged. As simple to use as the rest of the climate control on an earlish 911.
Chris
73 E
89 Carrera
Old 11-18-2019, 11:08 AM
aj88cab's Avatar
I don't think that is correct. At least in my '88, it is part of the dash lights, comes on whenever you turn on the car's lights. It's just to remind you how/when to operate the heater levers. Doesn't turn off if you turn off the heat (push down the levers).
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 11-18-2019, 11:23 AM
cmcfaul's Avatar
You may be right. The light was finicacy on the 73. Was definitely not always on with the head lights. Not to say it was not supposed to be. Thought it was some combination of top lever right, middle lever left, bottom lever right, hand throttle location lever up, defrost knob out... Like the enigma. 9 zillion combos to get the defrost on
Chris
73 E
Old 11-18-2019, 12:16 PM
theiceman's Avatar
Chris
73 E
89 Carrera
Old 11-18-2019, 01:56 PM
cmcfaul's Avatar
Well that clears up everything /
Lol
Old 11-18-2019, 02:18 PM
That light is fed by an un-fused circuit so be careful just leaving it buried under the carpet
Old 11-18-2019, 07:40 PM
