testing for a current draw with 2 batteries
I'm pretty certain I have a current draw on my '69E, but to be certain, I want to know if it matters which battery you work from? It doesn't seem like it would, but i wanted to check. thanx. steve
hi Steve ,no,it does not matter where you check...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
thanx so much, Ivan. s
Steve Meltzer '69 911E/bastard |
You need to disconnect the other battery if you're going to check for current draw.
Connect an ammeter in series with its ground cable (B) to measure parasitic current. Sherwood |
OK, thanx guys, i had no idea, so i'm glad I asked! I've done this test before, but not on a two battery system.
can someone explain the science and reasoning for dc'ing the non-test battery? thanx s
Wiring is like this. Ground Connection -|--BATTERY 1 (Driver Side) ++++|+++LOADS Ground Connection -|--BATTERY 2 (Passenger side)+|^ you have 2 separate ground connections. If you only measure at one, you will have current flow at the second as well.
OK, i got it. thanx so much. s
