How to secure reverse switch wire harness?
I'm sure I could McGiver some adelle clamps and zip ties, but is there a correct way to secure the reverse light harness to the transmission? The harness has a rigid plastic tube over part of it.
1978 SC Targa |
Red Line Service
Yes, You're missing bracket # 915 301 369 00 and reusable strap #999 513 007 40. They go where your harness passes the nose cover, then, 2 nylon ties around the starter, slide the protective tube up to there.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Perfect, thank you!
1978 SC Targa |
Marc,
pic?
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold ![]() |
Safe to assume this little tab, riveted to the side of the case, is to support the speed sensor wire (speed sensor removed in this photo)?
1978 SC Targa |
sola..yes that is it...
here is a pic of the bracket tie wrap
1985 911 with original 501 708 miles...807 421 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 11-19-2019 at 01:44 PM.. |
Red Line Service
Thanks for the pics guys, I didn't have one readily available.
No problem Marc it took me while;-) unfortunately the tie wrap seems to be NLA..
Ivan
1985 911 with original 501 708 miles...807 421 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Red Line Service
If you can't fid the 999 513 007 40, there's a longer one, 999 513 023 40.
Does anyone have a picture of where the two nylon ties go around the starter to hold the reverse switch wire harness?
Thread Tools | |
Rate This Thread | |
