Part # needed (84' 911 3.2)
I am looking for the part number (or name) of the copper tube/rubber boot that run from the venturi to the intake elbow.
This looks like it could be an expensive part and I have seen where people have cut off the the crimped section and replaced the rubber with some tubing/hose clamps.
I am hunting a vacuum leak and that piece of rubber is torn. However after smoke tests it doesn't seem to leak there. It is leaking between the airbox/MAF, getting a new gasket for that.
Thanks!
Old 12-08-2019, 02:25 PM
Take a look at PET Illustration 107-00. It should be part 24 or 24A.
24. 930-110-328-03
24A. 930-110-328-05
Old 12-08-2019, 03:16 PM
Administrator
Dmitry at Pelican Parts's Avatar
Thanks!
Hello - are you able to post a photo of the item that you're looking for?
Old 12-09-2019, 02:42 PM
sugarwood's Avatar
Download the PDF PET parts Katalog here
https://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
1986 Bosch Icon Wipers coupe.
Old 12-09-2019, 02:53 PM
sugarwood's Avatar
Old 12-09-2019, 02:55 PM
Thanks guys! It was this part:
https://www.pelicanparts.com/More_Info/93011032803.htm?pn=930-110-328-03-OEM
Old 12-09-2019, 02:59 PM
Hi. I ordered this part a few years ago. Expensive! I searched all the Porsche sites until I found the best deal. Mine had the same problem. But before your order I heard from a very experienced mechanic on pelican to put shrink wrap on the rubber section and heat up. Leak fixed!!!!save $200!
Old 12-09-2019, 03:04 PM
Try it!
