Diving in 911
Calling all brake gurus!
My head is spinning from looking at brake posts.... can anyone give me some guidance on fit?
I have a 76 911s running 16’s with turbo spacing in front. Hoping that SC calipers will work in the front. They are 3.5 spacing and I have the matched rotors. I want to leave the rears unchanged if possible. The system is not boosted.
Trying to get an idea of my options. Thanks Pelicans!
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 12-09-2019, 12:44 PM
Bill Verburg's Avatar
There is no such thing as turbo Fuchs
all are 7ET23.3 or 8 ET10.6 or 9 ET15 for 911 or 930 use, 15 & 16 are the same spec for the same width,
There is a 944 7ET23.3 w/ extra brake clearance and there is also a 944 8 ET23.3 also w/ extra brake clearance
The 944 7 can be used interchangeably w/ the 911 7 while the 944 ET would have a different use than a 911 8
For a '76 9111 w/ struts that have 3.5' mounts and A or S calier can be used. The A's were used on SC, there is also a wide A that uses a thicker rotor that was used on 3.2 C and can also be used here.
Good choice not to touch the rears.
Bill Verburg
Old 12-09-2019, 12:53 PM
Diving in 911
Thanks Bill!
Old 12-09-2019, 12:58 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
careful changing just the fronts. You dont want to change the bias to the front. Needs to be balanced. You can usually get what you need from the stock brakes by getting the right pad for your driving style.
Chris
Old 12-09-2019, 01:48 PM
Flojo's Avatar
Read:
The ultimate brake upgrade page.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 12-10-2019, 04:14 AM
