dshepp806's Avatar
No way would I attempt removal in 'situ...too much of a wrisk.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-24-2012, 03:48 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Yeah, it took 140 Psi to get it out of the block...Stuck Oil Pressure Sender
Who Will Live... Will See
Old 12-24-2012, 04:48 AM
In the meantime
The sender was bad, full of rust, no way it can meassure something.
I order the new sender, unfortunatelly it takes a month to get to my country. I meassure the preassure and was OK (15 to 65 PSI). In the meantime, I built a plug out of the same sender unit (see picture).
Definatelly, I'll address the torque issue when istalling the new sender unit.
Old 12-24-2012, 12:11 PM
Originally Posted by Jim Sims View Post
The torque to dismount the oil pressure sender can be very high - enough that the reaction force at the fitting into the engine case can break off or strip the integral engine case threads (it has happened). It is far better to dismount the fitting (by removing the hollow bolt) and pressure sender, mount the fitting in a vise and then remove/replace the pressure sender. There have been numerous "rigs" made with crows foot wrenches, etc. (and now one with a "shrink fit tube") but none of them appear the address the reaction torque or force hazard.
I just went through this. I could not get a 24mm wrench on the sender. Then I remembered the square block the sender screws into has a hollow banjo bolt through it. You loosen the second nut from the right 19mm and the whole assembly comes out. You could do real damage to the cases if you are not careful.
DO NOT put a lot of torque on that sender while it is in the car! As the poster above suggested take it out and put the brass block in a vise and then remove the sender.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 12-24-2012, 02:39 PM
