No way would I attempt removal in 'situ...too much of a wrisk.
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
83 911 Production Cab #10
Yeah, it took 140 Psi to get it out of the block...Stuck Oil Pressure Sender
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
In the meantime
The sender was bad, full of rust, no way it can meassure something.
I order the new sender, unfortunatelly it takes a month to get to my country. I meassure the preassure and was OK (15 to 65 PSI). In the meantime, I built a plug out of the same sender unit (see picture). Definatelly, I'll address the torque issue when istalling the new sender unit. ![]() |
DO NOT put a lot of torque on that sender while it is in the car! As the poster above suggested take it out and put the brass block in a vise and then remove the sender.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Thread Tools | |
Rate This Thread | |
