Help? 74 Rear CDI / Fuse panel / capacitor
Help? 74 Rear CDI / Fuse panel / capacitor.
Anyone an expert at this? Or anyone have photo of 74 911 Rear CDI / Fuse panel / capacitor? I need to understand how this capacitor hooks up. Thanks in advance for any help.
Old 12-20-2019, 06:32 AM
ROW '78 911 Targa
timmy2's Avatar
Just an AM radio noise suppression device. It wires up to the original style remote voltage regulator.
I don’t have a photo, but others may.
Definitely does not attach to the CDI box.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-20-2019, 04:20 PM
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 12-20-2019, 04:51 PM
Thanks, It was attache fate CDI for some reason. The voltage regulator is missing too and the wire were taped up. I guess it was removed.
Old 12-20-2019, 04:53 PM
Under the radar
Trackrash's Avatar
I could be that the alternator was replaced with one that has an internal regulator, so the original regulator was eliminated.
Looks like you have some work to do.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-20-2019, 05:35 PM
HA! Ive got it all figured out tother than the "noise suppression device". You no how this is wired in?
Old 12-21-2019, 05:21 AM
RPM sensor
Here's another photo that says it might be an RPM Sensor for cars with MFI.
http://www.early911sregistry.org/forums/showthread.php?133428-RPM-Sensor
Rex
Old 12-21-2019, 07:49 AM
ROW '78 911 Targa
timmy2's Avatar
Noise suppressor. RPM sensors are 3 wire units and look totally different. They went away in later years when they upgraded the tachs.
Factory manual for 1970 and up shows 2 noise suppressors on this page. Both marked as 7.
With the remote VR gone there is no need for it.
Dennis
Old 12-21-2019, 10:03 PM
Thanks! Is this for 73? Seems this one is much different. The Noise suppressor plugs into the CDI and another source.
Old 12-22-2019, 06:09 AM
You don't need it.
206 637 4071
Old 12-22-2019, 08:10 AM
The Noise suppressor plugs into the CDI and another source on mine. Doest show in the diagram.
Old 12-22-2019, 10:40 AM
ROW '78 911 Targa
timmy2's Avatar
Doesn’t show in schematic as it was added when a radio was added.
That is all it was for.
As others have indicated. Not needed.
Besides, looks like that one has melted the red wire insulation in the pic. Odds are it is dead anyways.
Dennis
Old 12-22-2019, 11:32 AM
Under the radar
Trackrash's Avatar
Those noise suppressors worked with the old points type voltage regulator. The points arcing in the regulator caused the noise. Since you don't have a regulator, you don't need the noise reducing capacitor.
Gordon
Old 12-22-2019, 05:03 PM
Thanks! Thats makes sense. Appreciate it!
Old 12-22-2019, 05:08 PM
This cap is not there for noise supplession.
The capacitor is not stock on the Bosch CDI setup, but it is a good idea.
The cap is used for reserve power to the CDI. I have a Daytona-Sensors CD-1 in my 1973 and this is their recomendation in their installation instructions:
" If the battery is mounted in the trunk, a
filter capacitor is required and minimum 12 AWG
wire should be used for the connection to the
disconnect switch or power block. You can use a
10000 UF 25V electrolytic capacitor such as our
P/N 102007 capacitor kit or Mouser
(www.mouser.com) P/N 539-CGS103U025RC3
and bracket P/N 539-VR3A. Connect the 12 AWG
black wire to chassis ground near the engine,
preferably where the battery ground cable is
attached. Do not extend the black ground wire.
Verify that the engine is properly grounded to the
chassis."
FULL INSTRUCTIONS:
http://nebula.wsimg.com/f38ed282eb5687afef42c38b04a0abff?AccessKeyId=1C324 6E298A5DEFACC7D&disposition=0&alloworigin=1
I am sure this is why you have an electrolytic cat in your installation.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 12-23-2019, 10:20 PM
chassis."
FULL INSTRUCTIONS:
Really? You've reversed engineered both CDI designs and concluded both designs necessitate adding a capacitor for proper
functionality and not for noise suppression as in the case of the Bosch CDI, right? You do realize that the later 911SC Bosch CDI,
i.e. basic same design but 6 pins, used no capacitor.
Dave
Old 12-24-2019, 07:53 AM
YUP....you read it right. A capacitor in the power source line with the battery so far away makes great electrical sense and gives you a little reserve power when needed. I high capacity electrolytic has to help with no downside.
just because Porsche did not use in years ago means it is a bad idea.
Do you want to see my data and research???
03 Boxster
Old 12-24-2019, 09:42 AM
Yes, where are the data, i.e. Bosch vs Daytona, each with & without capacitor?
The data needs to be in graphical form indicating coil primary voltage versus RPM.
Dave
Old 12-24-2019, 11:15 AM
OK Loren, oh I mean "Dave"........let me dig up my charts.
03 Boxster
Old 12-24-2019, 09:36 PM
Whew! Nerds . Love it!
Old 12-26-2019, 05:21 AM
