New kid in town
71T Targa's Avatar
Which way do I turn the distributor to advance the timing?
Simple question really, I just don’t want to go with ‘turn it one way and see if it advances. If not turn it the other.’
Thanks all, Joel
I wish I still had 9111113443...
Old 04-02-2003, 09:01 AM
advance would be oposite rotor rotaion.
i would not adjust it with out a light. 'bout 30 smolls at wally world.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 04-02-2003, 09:05 AM
New kid in town
71T Targa's Avatar
So that would be counter-clock-wise?
I have a light, I just don't want to spend any more time at 6K than I need to.
Old 04-02-2003, 09:15 AM
i'm not sure about your vintage. it did change directions at some time. take the cap off and put the car in 4th and push it a little. you should reach maximum advance way before 6k? i would ask john 'the man' walker.
Old 04-02-2003, 09:27 AM
Set it a 0 degress at idle and check the advance. It should be at 35 degrees at6K. The car runs great there. On my 69 i set it 4 degrees ATDC to get 30 degrees BTDC at 6K. Your distributer may be a little different. But if you want it at the factory 30 degrees BTDC at 6K find the idle setting that gets you there. Then whenever you set it you can set it at idle and be confident that it will be correct at 6K. I hated revving to 6k also, mostly because it was too loud.
Hope this helps.
Jim
69 911 2.3Ez
85 928S
Old 04-02-2003, 12:41 PM
