3.2 question: How to test for impulse to fuel injectors?
I need your advice. I believe I’m at the point of determining whether the fuel injectors are all stuck, or the DME box is bad.
This is for the 1984 Carrera that has been in storage for twenty years. It lit up and sounded great with a whiff of starting fluid this morning, but won’t run otherwise. I have replaced the fuel tank and fuel pump, cleaned the fuel lines, installed new DME/fuel pump relay, and new fuel filter. With terminals 30 and 87b jumped per the factory manual, the pump runs and fuel circulates and comes back the return line to the tank. Also, with the relay plugged in, the fuel circulates with the starter cranking. However, it won’t run at all, zero, except with starting fluid, and then sounds perfect for a couple seconds, so I must be getting no fuel into the cylinders. I have confirmed that with the ignition on, there is 12 volts to the injectors. I don’t know how to check the other terminal on the injectors, the one which I think is the impulse from the DME. Also, can I check at the DME box? I’ve read the Bentley manual, but it is a bit vague and I can’t tell if my multimeter is the right tool. Can you talk me through it? I guess it is conceivable that the DME is OK, but that every single injector is stuck from being unused for 20 years. So that is why I want to do the impulse check. Thanks very much, Jeff
I know the injectors fire with a ground signal from the DME.
My guess is the injectors are stuck. I've head you can soak them in acetone and use a 9v battery to actuate them in an effort to clean. I opted to send mine to mr injector and they came back good as new with flow specs for not much $$ |
Noid light.
Or a scope, like an oscilloscope.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thanks!
If you want to test the injector signal, use a scope.
As you identified, one side is 12V, the other side gets connected to ground by the Motronic ECU (pin 14 and 15). It looks like they apply a peak-and-hold signal : ![]() In any case, you can relatively easily remove the fuel rail with the injectors on it and send the injectors off for testing / cleaning / retesting and the rubber parts and fuel screens will be replaced. What I am wondering, are you sure it is a fuel problem ? It seems that running 'a few seconds' simply on a small burst of starting fluid into the air intake is long ? Maybe your idle mixture is not correctly setup (not enough air/oxygen ?). I built myself a breakout box to save me some time in debugging these kind of problems, but it can be done by measuring at the terminal of each sensor too... ![]() Anyways, the official DME test plan calls for the following debugging steps : 1. Test ground connections: on intake runner nbr 1, near the fuel filter, strap between body and transmission Test all the plug connections (clean, well seated) : 14 pin connector in engine bay, the three connectors on the left side, the 6-pin connector supplying the injector signal, plug on the ICV, idle throttle position switch, WOT switch, AFM plug, connector on each injector, DME connector (35 pins), seating of DME relay 2. Check fuel pump at starting. It should run, if not check fuse Check 12V power to the DME 3. Check speed sensor output with scope : sinus with amplitude > 2.5V 4. Check reference sensor input with scope : single oscillation >2 V 5. Check iginition signal (to coil) with scope, check wiring from coil to distributor and from distributor to spark plugs. Check distributor cap & rotor. 6. Check AFM power input (5V), check output from sensor plate, check output from air temp sensor 7. Check fuel pressure at the rail test point : 2 bar, without vacuum on regulator 2.3 to 2.7 bar. This 'no vacuum' value should also be seen when you operate the fuelpump without the engine running. 8. Check ICV operation 9. Check throttle idle switch operation / check full throttle switch 10. Check engine temp sensor II (top one of the left three connectors) for resistance 15-30 deg C (normal temps) - 1.4 - 3.6 KOhms 11. Test injectors If engine runs : pull injector plug one at a time : engine should run rough / rpm drop If not running : test injector coil ohms : 2-3 Ohms Check if signal from DME arrives by scope connected to cable plug 12. CO adjust , idle speed ajust 13. Check for air leaks in system & check alititude correction box (bridge) I am using my old analogue scope in the example above, but I'm sure it can be done with one of those $35 'DSO shell' scopes on amazon since the signals are not really very high frequency. Last edited by FrankM_; 12-28-2019 at 12:48 PM.. |
Better go to a shop that has a professional testing/cleaning rig or build a small electronic drive that doesn't blow up the injector when you use it too long.
Thanks for the input. And Frank, thanks for the checklist and other information. This will keep me busy for awhile!
Hey Frank, where in Belgium would you send your injectors to ? I went to a Bosch shop but they sounded really surprised when I asked them if I could bring in 6 bags with a fuel injector for inspection/rebuild...(I'm also on the Belgian porsche forum; gdpsuz1982)
Hook a battery, can even be one out of a 9 volt flash lite, to the injectors and see if they click. some times that is a way of freeing them up.
It is not cheap though, incl tax I paid about 32 eur per injector (including every renewable part renewed off course). They are also a good stock for hard to find parts and rebuild a/c compressors ec... |
This. Much easier and less expensive than an oscilloscope. The scope it cool, but most home mechanics don't have one handy.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Puny Bird
Noid light is nothing more than a test light, all FI wires worked.
Turned out to be the "rebuilt" fuel injectors, replaced the injectors with new FiveO units and she fired right up on all /6. New, but way smaller issue, is the throttle plate isn't returning to zero. It's almost there with the spring I have but just won't go the last 1% and I can hear a solenoid/limiter click when I push on the return. I'll have to look for a thread on solutions for the throttle return.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Check bushings on throttle links under the car.
There are oilite bronze bushings on this site ,way better than the plastic original. |
