Short shift Kit - Broken Component
Anyone out there know where I can get a replacement for this broken part in my short shift kit and what the piece is called? Thanks
1970 914-6 #2615 (Metallic Green) - SOLD 1974 911 US Carrera Coupe #63 (Lime Green) 1973 911 T Coupe #1891 (Gemini Blue) |
The part is called the Shift Pivot Housing.
Have you asked Pelican if they might have it as part of a return or something?
Current: 1984 911 Targa Whale Tail "Gemma" 2014 Boxster S (wife) "Sir Jenson" (She named it...not me) Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4 |
No I have not tried that yet, but will try your suggestion.
Thanks,
Weld it?
Yeah...what he said. Got anyone you know that can just weld it back together?
Was thinking that as well, but if I can just find the one part to buy it will probably be no more expensive than the cost to pay someone to weld it. Still something to consider if sourcing a replacement part is not possible.
1985 911 with original 501 708 miles...807 421 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
i c ok, i only had good experience;-) times changed.....thanx for the info
Ivan In that case look here these are nice guys on the east coast Ask for Roger or Matt www.retroautomotiveproducts.com
RETIRED
He used to be referred to as MS Road and RAPE....but that was 20 years ago when they still had swap meets in California. If it's under new management, I'll apologize.
I have this if your interested
That looks like more of the stock part. The short-shifter assembly is much different. Not compatible.
Yes the shift lever is stock, however the broken part would be a direct replacement
Thanks Harpo. Just sent u a PM.
I just installed the short-shift kit from our host about a month ago. As an experiment, I tried using the stock Pivot Housing just to see if it would work. It did not. You physically can't shift. The short-shifter Pivot Housing and VERY different from the stock. FYI.
If you look closely at the OP's pic...you can see it matches the the part in this link:
https://www.pelicanparts.com/More_Info/91142493100OEM.htm?pn=911-424-931-00-OEM&bt=Y&fs=0&SVSVSI=911M Definitely not the same as the part Harpo is showing in his pic. It won't work. Sorry.
Thanks JT. Appreciate you looking at this closer. Looks like my search continues then.
Thread Tools | |
Rate This Thread | |
