86 carrera check strap pin problem
Replacing the check straps on both doors starting with the l/s. The pin holding the arm in place was almost impossible to remove it was mushroomed somewhat. After grinding a portion of the pin I used a punch to drive it out. So I ordered the pin kit from our host and the pin has splines on it and the diameter is to large to fit through the strap and jam flange. I don't want to use the pin I removed as it's a solid steel pin that may fall out after I install it. What are my options here for what should be a simple repair? A bolt and nut, Split pin ?
Old 01-04-2020, 08:08 AM
6mm bolt and a nylock nut. Tighten until it quits popping.
206 637 4071
Old 01-04-2020, 08:40 AM
Uncertifiable!!!
Uwon's Avatar
First of all, loosen the straps if they are stiff. Search this forum for instructions which require disassembly. I loosened mine so the midpoint “click” almost disappears.
I used the smooth pin with circlip for the hood struts as I don’t really like the gnawing arm movement against the edges of the thread.
Hope this helps.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 01-05-2020, 05:11 AM
