pit pit is offline
911 Carrera 1987 Stone guard
Am interested in purchasing rerar stone guard decals . How to "install " them? Glue? Screws?
Old 01-08-2020, 04:51 PM
rokemester's Avatar
Suggest finding a top notch wrap shop in your area. The wrap technology has advanced immensely since the 80s stone guards.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 01-08-2020, 06:19 PM
Synchro Joe's Avatar
Maybe some pointers here: Stone Guard Installation 84 911
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 01-08-2020, 06:27 PM
proporsche's Avatar
or you can use clear stone guards.....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-09-2020, 06:02 AM
There are also magnetic ones available, that way you can reposition or remove and reinstall at will.
Here from Werks911, but I'm sure there are other suppliers as well.
Old 01-09-2020, 11:13 AM
MichaelSJackson's Avatar
The "original" black guards are thick and stiff. Also they are peel and stick.
Before you apply, make sure they are warm enough to be very flexible. The contact surface too. Have your heat gun plugged in and handy, just in case.
Surface should be clean, clean, clean. No wax, etc. Might even use a clay bar?
The adhesive is very good and doesn't allow second tries.
Find the spot to start where the bottom will be parallel with the car's lines. Then I started at the bottom of the wheel arch and followed it up around the arch. After the curve edge was attached, I worked outward. Practice once or twice before actually exposing the adhesive?
Old 01-17-2020, 10:51 PM
