jmz jmz is online now
jmz's Avatar
a new dash is hard to install, any suggestions?
I am trying to install my new/used dash into my 1974 911 and am wondering if there is a better way?!?!
Is this jus a matter of man-handling it to get all the studs lined up etc. I've already broken a few of the plastic push clips...I'll use a few cleverly placed pieces of marine grade velcro to remedy this. I looked in my factory manuals and no luck there...I am concerned that if I torque on it too hard I'll cause a crack.
any suggestions??
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 04-03-2003, 08:32 AM
TurboRuf's Avatar
jmz,
Slow down! This is a delicate process and doesn't require force. I am guessing you already have the windshield removed? Did you buy Wayne’s 101 Projects? Hopefully you have answered yes to both of these questions.
If you properly fit the dash first, you only need to lightly tighten the studs. When you successfully line up with plastic clips, the studs should fall right in place. Sitting inside the car you will have to angle the dashes backside upward. Push the dash into place then push the backside, closest to the windshield, down into the plastic clip receivers. At this point the dash should be in place, now tighten the stud bolts.
85 930 Ruf BTR
Old 04-03-2003, 09:04 AM
jmz's Avatar
the big problem is fitting it between the a pilars. it is very tight
Old 04-03-2003, 09:08 AM
jmz's Avatar
oh and yes the windshield is out and no to wayne's book.
Old 04-03-2003, 09:11 AM
LeRoux Strydom's Avatar
check out this thread about my experiences with dashboard replacement, and get Wayne's 101 book:
Replaced dashboard - pics
Good luck
LeRoux
'90 964 C2 coupe (sold )
There are no old Porsches, only new owners.
Old 04-07-2003, 01:44 AM
