What is this relay?
Was cleaning up some of the wiring and found this guy. It looks like it’s hooked up to the fuel relay. I’m guessing it was for an old alarm.
It has an led wired up to it. What do you think? Am I ok removing it? ![]() ![]()
Analog Air Cooled
I’d see what color wires go to it. Defiantly a relay w standard DIN numbers. There are a bunch of those, from lights, to cruise control, air con, fog lamp..
What year car? 30 is Pos from bat terminal, you could test it on each fuse and see where the continuity lies..
86 Targa 91 964 13 6 SPD Cayenne |
Non stock add on relay maybe for alarm. See where the 87 wire goes.
Unplug the relay, and see if the car runs.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
87 goes back into the fuel relay. The whole thing just splices into the black wire on the fuel relay. I'm 99% sure I should just cut it out and connect that wire back together.
1978 911SC - 3.2 1971 914/4 IG - @etcetera911 |
Yup, aftermarket alarm fuel cutoff relay.
When in doubt....pull it out!
Same philosophy as in pruning....if it's brown....it comes down.
Old dog....new tricks..... |
Yep, pulled it out and reconnected the wires. Everything starts up fine. Thanks for the help everyone.
