Troll Hunter
Wish I could be more help. I"m rooting for you!
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
SEVENT9
Thank you brother Nick!! lol - rooting for me is all I need right now. I am looking on the positive side. I am learning a lot about simple things and it's a great learning curve. Speaking of which - perhaps you can lend your thumbs-up or thumbs-down to today's test:
A timing light arrived today (figured I should add one to my growing list of necessary tools!) so I hokoed it up as you can see below to see if I have spark. I read on teh forums here that I could test my coil using a this method:
If I have done this correctly (as shown by pic above) then I get the following:
Having never used a timing light before I have no reference point to know if this is correctly wired up or not and therefore I don't know if the results are dependable. If I have done this correctly then I have no spark from coil to dizzy which rules out the dizzy correct? So I looked again at the CDI:
If this is also correct then I have a bad coil right?
- - - - SEVENT9 '79 SC Black: My first 911 & my birth year!! ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html Last edited by thefaculty; 01-17-2020 at 03:13 PM.. |
ROW '78 911 Targa
Is that a Bosch silver coil made in Brazil?
Odds are it is a good candidate for the trash bin. Timing light not flashing is a good indicator of a bad coil. MSD Blaster 2 part # 82023 is a suitable replacement for original mounting location.
SEVENT9
- - - - SEVENT9 '79 SC Black: My first 911 & my birth year!! ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html |
Ignition coil........
PDan,
Is the silver ignition coil you have is the notorious Brazilian coil? The CDI plug should be connected and with the inductive timing light clamped at spark plug cable #1, turn the ignition switch to START and watch for the ignition signal (probe light). This is the basic procedure to verify presence of ignition signal for your motor. And don’t forget to press the trigger switch. I usually place a rubber band on the trigger switch during testing and start ups. Keep us posted. Tony Last edited by boyt911sc; 01-17-2020 at 03:27 PM.. |
SEVENT9
Just so we have gone over everything I have done I also did the following checks:
So coil? I think it must be right? If I am replacing the coil I wondering if going the full MSD upgrade would be worth it at this time?
Troubleshooting.........
Dan, If I were doing the troubleshooting, I would first test and verify that I have a good ignition system and get the motor running. Keep it simple. Borrow or use a good ignition coil for the test. Once the motor is back running, then you could do your next project. You could do what ever you want that you are comfortable. Keep us posted. Tony |
ROW '78 911 Targa
Dan, I’ve been running the Bosch CDI with the blaster coil for 9 years now.
As stated, swap out the coil for a known good one if you have one available. Always Test and verify before replacing stuff. One step at a time. Easy to throw money out the window just replacing things that don’t need replacing...
I went thru 2 coils before I remote mounted the 3rd coil off of the engine fan to the sidewall. Track driving induced high frequency vibration was removed as a factor.
1980 911 - Metzger 3.6L 2016 Cayman S |
SEVENT9
Great to know the Blaster works with the Bosch CDI. For some reason I thought they had to match makes. I'll get a coil to test and go from there. Thanks everyone - will update asap.
SEVENT9
Timmy - are you running the Resistor-less rotor with the Blaster coil or is that only necessary if you run the MSD box as well? I have read they need switching out but are hard to find.
In the photo it looks like the timing light clamp is grounded to
the spark plug wire sheathing. A grounded bolt on the chassis would be better: no? |
ROW '78 911 Targa
I use the normal SC Bosch rotor.
It is the MSD CDI that can have problems with the resistor type. Not the coil.
SEVENT9
Thanks Dennis! After a lot of reading today I think my Green Wire may be the culprit but I am unsure on if my tests are showing this to be correct or not. Any help you could give would be super! Thanks!!
- - - - SEVENT9 '79 SC Black: My first 911 & my birth year!! ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html Last edited by thefaculty; 01-21-2020 at 10:03 AM.. |
SEVENT9
I cannot tell you how happy I am to report back that the new coil arrived today, it went in and she started faster than ever before!!!
I cannot thank you guys all enough for your help, experience, wisdom and patience with me! For most of you this is simple stuff but for a newbie like me it's a milestone. Taking a car from a non-starter to a nice clean start without taking her to a shop is a big deal for me and I couldn't have done it without this forum! THANK YOU EVERYONE!!!! And now enjoy the sweet sound of success!! ![]()
- - - - SEVENT9 '79 SC Black: My first 911 & my birth year!! ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html Last edited by thefaculty; 01-22-2020 at 10:29 AM.. |
ROW '78 911 Targa
Good news, and you learned a lot.
Troll Hunter
Woohoo! Nothing like getting a car (any car, really) to start after it wouldn't. Good for you Dan, good for you!
