Slow old car
Engine out, bored, what else to replace?
Subject says it all.
My engine has been out since late November for a head job and stud change out, and I’ve been taking the opportunity to fix up other parts of the car.
So far in the engine bay I’ve added an engine sound pad, cleaned up some wiring, changed the shift shaft seal on the trans, cleaned a bunch of gunk, doubled up my rear deck strut, and replaced an oil line.
Otherwise, I’ve replaced my shifter linkage bushings and changed out my door lock cylinders to match the ignition.
The fuel filter and accumulator don’t seem too awfully hard to change with the engine in, and everything seems to be fine there, is there any reason to preemptively change those? What else do you wish you had changed while you waited for your engine?
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 01-26-2020, 03:58 PM
Under the radar
Trackrash's Avatar
Fuel lines.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-26-2020, 04:21 PM
I don't always add to the expenses but sometimes it is just the thing to do.
Replace your rubber seals around the engine bay.
Repaint your tins
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-26-2020, 04:39 PM
3rd_gear_Ted's Avatar
You could replace your clutch cable to go with your new clutch.
Also check the pedal cluster for wear.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 01-26-2020, 04:44 PM
Slow old car
This is generally my train of thought. While removing this engine is by no means a difficult job, I'd like to make the most of it.
I've owned this car since last May, and it's been both 1) in my possession, and 2) drivable for a grand total of 2 months, so once the engine is done, I'll be ready to put some miles on it in earnest.
These are great suggestions, thanks everyone!
Mike
Old 01-26-2020, 04:53 PM
Clean and repack the CV joints.
Throttle cable?
Also, check the brake vacuum booster line.
Old 01-26-2020, 05:15 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Repaint your tins
Powder coating would be sweet and pick up a package of the shiny 6mm fastener hardware.
1981 911SC Targa
Old 01-26-2020, 05:22 PM
The bushings on the trailing arms where they attach by the transmission tunnel are much easier to get to with the engine out.
Rutager West
Old 01-26-2020, 06:48 PM
DO THIS.
Much easier to get to is such an understatement.
Old 01-26-2020, 08:32 PM
+1 on fuel lines and those trailing arm bushings. (I managed to replace trailing arm bushings with the engine in the car during my suspension rebuild - was not easy. Wish I had pulled the motor.)
Old 01-26-2020, 09:25 PM
