Stupid Question Regarding Fan Belt Swap w/ Factory Toolkit on a 71
Ok, maybe I'm missing something...
The fan is a 24mm nut. The fan is held with the special tool (2 pins for his model).
The factory tool kit doesn't have a 24mm wrench. But it has a fan belt.
So help me out. How was one (or not?) expected to change the belt on these with the factory tools?
Not that it matters, have a tool kit with an extendable 1/2" ratchet at 19mm, 24mm sockets...
Old 03-03-2020, 06:46 AM
proporsche's Avatar
every factory tool kit had the 22mm or 24mm wrench for the alternator nut..what is your other question?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-03-2020, 07:26 AM
Ivan
so 71 toolkit had a 19/22mm box wrench, the nut on fan is 24mm ... ???
I must be missing something here...
Old 03-03-2020, 07:36 AM
HarryD's Avatar
You have a later alternator on your car. Probably with the internal regulator as well. You will need to do what I did and buy a 24 mm wrench. I have the same situation on my 1973
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-03-2020, 07:47 AM
AH! Got it. The logic wasn't computing... I know I have the fan from the 71 (case and lower part is a 77), didn't consider the alternator, and yes, looks like it may be later.
Old 03-03-2020, 07:59 AM
