LinkBack | Thread Tools | Rate Thread |
Stupid Question Regarding Fan Belt Swap w/ Factory Toolkit on a 71
Ok, maybe I'm missing something...
The fan is a 24mm nut. The fan is held with the special tool (2 pins for his model). The factory tool kit doesn't have a 24mm wrench. But it has a fan belt. So help me out. How was one (or not?) expected to change the belt on these with the factory tools? Not that it matters, have a tool kit with an extendable 1/2" ratchet at 19mm, 24mm sockets... |
every factory tool kit had the 22mm or 24mm wrench for the alternator nut..what is your other question?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I must be missing something here... Last edited by spyerx; 03-03-2020 at 07:38 AM.. |
You have a later alternator on your car. Probably with the internal regulator as well. You will need to do what I did and buy a 24 mm wrench. I have the same situation on my 1973
Thanks |
