'73 911 T Targa
Unfused circuits
After reading a few posts about smoke and molten wires, I think I’m going to undertake a project to add fuses to the unfused circuits in my ‘73.
Is there a comprehensive list of all the stuff that’s unfused? |
Great question. I would like to know also.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
El Duderino
The instrument light cluster is one. There is an old thread here that is a great write-up. Super easy. You just install an inline fuse off the ignition switch with a 1 or 2A fuse. I’ll look for it and post in a few minutes.
Another one is the front A/C condenser fan. It’s on a fused circuit but it can still start a fire (right by the gas tank) if the motor seizes. Several people have lost their cars this way. Porsche added an inline fuse sometime in the late 80s after they realized this error. Another easy fix and Pelican also sells a plug and play kit if you don’t want to DIY.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
El Duderino
Gauge light fuse fix:
Dash lighting fuse installation
El Duderino
Pelican A/C condenser fan kit:
https://www.pelicanparts.com/More_Info/PEL61207700.htm?pn=PEL-612-077-00&bt=Y&fs=0&SVSVSI=801
1988 Carrera
Not a fuse thing but I like the ceramic plugs in the head light as a good upgrade. As is the headlight relay.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too Last edited by shadowjack1; 03-14-2020 at 06:18 AM.. Reason: ** |
2000 Boxster S and 2016 Audi A6 Last edited by Pedro '84 Coupe; 03-14-2020 at 06:40 AM.. Reason: typo |
I couldnt find the thread where almost all the wires were melted behind the gauges that was scary! I seem to recall the cig lighter and glove compartment light are unfused aswell but they might be on the dash light circuit?
82 SC , 72 914 |
It's better practice, if possible, to locate fuses in a central or obvious location so it can be easily inspected should there be a malfunction years after your memory fades.
For example, the main fuse box. Sherwood |
Unfortunately the fuse Porsche added is too highly rated to blow before the AC blower wire melts. Hence the need to still add a lower rated fuse in this particular circuit.
AutoBahned
be sure to check the wiring diagram for 1973 or 1973.5 whichever you have most of the posts above relate to later cars yours has all those unfused issues but maybe more I'll be interested to see if there are others since I have a 1973.5 |
Diss Member
The basic issue is Porsche took the power from the battery, bypassed the fuseblock that is right next to it, and ran it into the dash to all the various controls, then they ran the wires back to the fuseblock, and then finally they ran them to the various loads.
It makes no sense. The fusible protection should be as close to the power source as possible. It is the one part of the car that just drives me nuts.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
The easy way is to add inline fuses from where they powered from the back of the light switch. |
'73 911 T Targa
A follow up question...
Does anyone know what values the fuse should be for each of these circuits? |
Analog Air Cooled
I’ve read 3A on the triple BK/BL dimmer lights. FWIW, I used the 2.5A inline fuse from the orig radio wiring for my ashtray light.
86 Targa 91 964 13 6 SPD Cayenne |
Heater lever is not fused and ignition hot lead
72 914-6 GT Conversion 2.7 82 911 SC Coupe 78 SC Targa Hotrod |
'73 911 T Targa
yes different separate circuit. They are unfused on constantly hot (not switched).
'73 911 T Targa
Crimeny! What were these guys thinking?!?
'73 911 T Targa
Any idea where the “other end” of that connection terminates ?
