Dual-stage switch knob illumination
Hi Pelicans,
I need Your help. I got stuck trying to figure out the illumination of dual-stage switch. I believe this type of switch is used for dual-stage rear window heating as well as front + rear fog lights Does this type of switch have any illumination when operational? If so how/where to find it? It has a green semi-transparent top cover ![]() There seems to be no (place for)bulb socket not glow stick on the bottom ![]() Finally the knob seems to be fixed to the control arm ![]() Can anyone help? Am I right hoping this switch can be used to connect front + rear fog lights Marcin
'70 911T '75 911S '81 928S |
It does illuminate. I found the wiring on here somewhere. Mine are installed and I might be able to take pictures later. When all the way in there is no illumination. When pulled out to step 1 or steps 2 the Illuminati is the same, on.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
I'm good with tools.
Yes it does light up. Gently pry the the green disc out of the rubber and check the bulb. Might just need a bulb.....
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Thank You both @Duc Hunter and @AG81
I will try to dig into it from the top.
That is a switch for a 74 to 89 , rear defrost. I have one for a 69-71 of you need a picture or need to buy the real deal.
Robert Williams 70' 911T |
