TPR (throttle positioning regulator)........
Seeking help from ‘75 CIS owners. I need some pictures of a ‘75 CIS engine that shows this side of the motor. Particularly a view like below:
The picture above is a late SC ROW engine and using it as a view sample. There are some discrepancies regarding TPR I like to investigate regarding CIS information. Thanks.
Tony
Old 04-02-2020, 11:19 AM
proporsche's Avatar
Hi Tony what exactly are you after??
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-02-2020, 11:47 AM
Happen to have a '76 about ready to go in.
206 637 4071
Old 04-02-2020, 12:19 PM
al lkosmal's Avatar
Tony,
I just dropped a 75 CIS this morning and I'm headed back out to work on it. I'll take a couple of pix and post.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 04-02-2020, 01:23 PM
E Sully's Avatar
According to Jims CIS Primer, US models dropped it in '75 with WUR change, but not till '76 on Euro models.
911 CIS Primer - Parts ID
Ed
1973.5 T
Old 04-02-2020, 01:29 PM
1976 CIS motor.......
John,
Thank you for the time posting the pictures of ‘76 CIS engine. I am investigating the ‘75 CIS motor for TPR. People have been mentioning that the ‘75 CIS don’t have TPR. But my documentation and experience prove otherwise. So I am intrigued by this discrepancy. This is the reason I am seeking help to get to the bottom of this anomaly.
Tony
Old 04-02-2020, 01:42 PM
‘75 CIS motor.......
Originally Posted by al lkosmal View Post
Tony,
regards,
al
Al,
Take your time. Please post the picture/s when you get the chance. Thanks.
Tony
Old 04-02-2020, 01:45 PM
al lkosmal's Avatar
RGruppe #669
Old 04-02-2020, 01:49 PM
E Sully's Avatar
May have also been a change during 75 production.
Ed
1973.5 T
Old 04-02-2020, 02:03 PM
Great pictures.......
Al,
The pictures show no TPR for the ‘75 CIS. Glad you have pictures to convince me. However, how do you explain for some of the ‘75 CIS that have TPR? I have seen them and not imagining things up. Maybe the change was made during production dates? Thanks a lot.
Tony
Old 04-02-2020, 02:20 PM
I see the TPR actuating rod still on the throttle body, maybe they changed the WUR to vacuuum.
Old 04-02-2020, 02:33 PM
Critical document.........
Ed,
This is a very important and critical document regarding the TPR discrepancy. This shows that TPR existed in model year ‘74~’75. Maybe not for the whole 1975 production (?). I agree with you that a change was done during the production.
Thank you for sharing this document.
Tony
Old 04-02-2020, 02:35 PM
E Sully's Avatar
Porsches documentation is rough, and they seem to have a habit of changing things during produtction. Als does not show the TPR, just the white shaft it would go on. You can see in the image from one of Bosh's manual I posted in previous post, they show 2 different options. I have 2 complete 73.5 CIS systems. One early one has air flow sensor 0 438 120 002, and end of production 0 438 120 004
Ed
1973.5 T
Old 04-02-2020, 02:42 PM
Registered Minimalist
75 911s's Avatar
My 75 was very original. No TPS on my motor.. It's an early 75 with the 4 bolt half shafts. I also wonder if CA delivery had anything to do with it? Mine was CA delivery with Thermal reactors, EGR, long airbox snout.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 04-03-2020, 05:17 AM
Need side view..........
Al,
Could you post a picture of your ‘75 motor from the driver side view. Interested to confirm where this vacuum hose is connected.
Thanks.
Tony
Old 04-03-2020, 05:37 AM
al lkosmal's Avatar
Tony,
The engine is now disassembled down to the long block stage.....but i did remove the intake in one piece so I'll take a pic today and post.....
regards,
al
RGruppe #669
Old 04-03-2020, 08:07 AM
al lkosmal's Avatar
Tony,
Here you go....
RGruppe #669
Old 04-03-2020, 11:22 AM
Thanks for the additional pictures........
Al,
Thank you for posting the pictures. They really helped me a lot straighten some of the lingering questions in my mind. Stay safe.
Tony
Old 04-03-2020, 02:03 PM
al lkosmal's Avatar
tony,
Glad to help...just happened to have the right engine at the right time. Stay safe/healthy
regards,
al
RGruppe #669
Old 04-03-2020, 02:05 PM
E Sully's Avatar
Weren't there 2 models in 1975, 911/43 USA and 911/44 California only? Not to mention that there were Euro models also.
What engine type is yours Al? Did they have the same WUR?
I believe that the Cali car was 5hp less also.
Were there still 3 US options, 911(green shroud), 911S, Carrera?
Ed
1973.5 T
Old 04-03-2020, 02:32 PM
