Functionista
The picture shows the valves sitting correctly in the seats. Too many heads get mis-cut during valve jobs leading to poor flow from recessed valve seats.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
clean machine
the 75 2.7S is cleaning up nicely. This is just a stock 2.7S CIS engine....but they need a little love too!
Cams are timed.....so it should be on the test stand, next week. I still need to test the injectors, refurb the engine shroud, wiring harness....test the CIS system, etc......but getting close to......fire..... regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
getting closer
Should have this on the test stand tomorrow/Monday.........looking a lot better now....
regards, al
it's a runner
From this :
to this....... It's a runner...still some tuning to do, checking the WUR etc...but plan to have it installed and back in the 75S tomorrow or so........even the stock ones are fun to build. stay tuned al
all is good in my little world....
It all turned out right in the end. The stock 2.7S is installed back into the 75......starts, runs, stops....no drips on the floor.....a good day...........
regards, al
Nice work Al - I had Ollies do all my magnesium engine block inserts 12 years ago - and 60,000 miles later, no issues. Your engine work looks great. Glad it worked out well.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Porsche Addict
Throw in a tire/wheel size debate for good measure.......?
Lawrence - 1986 911 Carrera Coupe Grand Prix White 1959 Land Rover Series II 1962 Volkswagen Sedan Ragtop 1959 Porsche 356A Coupe 1971 Porsche 911T coupe |
Rex, good to hear from you. Ollie's is definitely the place to go....I have a 2.2 to 2.5 engine rebuild in the works....my case has been at Ollie's for 2 months now and will likely be there for another month....really putting a crimp in the schedule..... regards, al
