Super Moderator
cstreit's Avatar
Souk, I thought the same thing and wouldn't use one on the Duc regardless, however I know a number of people that have used them forever in the 911 motor with no problems...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-11-2003, 07:37 AM
Senior Member
Superman's Avatar
I never had a ML problem in my MC days and further, the 911 engine timing chain environment is WAY different from the final drive chain on a MC. MC final drive chains do not last 20 years and 200k miles. To say the least.
Mocha 1978 911SC. "Coco"
Old 04-11-2003, 07:46 AM
Senior Member
Doug Zielke's Avatar
Just a random thought......
Masterlinks on m/c chains have fallen by the wayside somewhat, with the advent of o-ring sealed chains. The last one I installed (Regina brand), was of the endless variety, using riveted pins, no link. As one would imagine, they are not as easy to install.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-11-2003, 08:05 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
One thing about master link chains, I know this applies to motorcycles and makes sense in the timing chain application as well. Make sure when you install the master link, its closed end is the facing the direction of rotation. So, if the chain rotates clockwise, the ML's closed end would pass the 6 o-clock position prior to its open end. The reason for this is if the chain/master link happens to hit the side of the case while the engine is running, it wont get pushed/knocked off its pin causing the chain to come apart.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 04-11-2003, 08:27 AM
Thanks for all the suggestions and I will definitely try to see what is going on soon. It sounds like we have agreement that it is not on the intermediate shaft correctly and I will get my flashlight in there and see what the story is. It is very weird that it just decided to do this -- it turned over fine many, many times on the engine stand with the solid tensioners and I maintained constant pressure on the chain while swapping in the pressure fed tensioners. I have to go out of town for a couple of days starting today, so it will be until next week when I find out for sure but I will post again with the findings. I'll try to take a picture if I can get my camera in there somehow
Tom: Thanks very much for the generous offer on the chain. I will let you know if I need it. Thanks.
I wish I knew more about this engine. I bought it along with a bunch of stuff and from all appearances it was rebuilt with no miles on it. All of the ports still have the machinist's blue from the valve job and the ports surfaces are clean as a whistle. It looks like it might just be a top end rebuild, but when I took off the inspection plate and shined a flashlight up inside it looked awfully clean and nice. Anyhow, it came as part of a package deal that included three engines, a chassis, etc, etc, etc. for a great price. Everything has been really good so far (One Pelican member bought the other 2.7 liter and it is in his 914 and running well and KeithO64 has the other 2.2 motor and it is running fine in his car) so I did not rebuild it myself, but I kind of wish I had. If I had done it myself I would have been confident in all of the pieces that went into it. I am putting this in and crossing my fingers. I will start soon on my 2.4 and 2.0 liter engines (by the way Wayne, the new book is great and so is the CD! Many kudos for doing something for all of us.)
I am glad to hear that I can replace the chain (if need be) without disassembling the engine. Master link chains are not ideal, but if it is a factory Porsche part, I imagine that it should work pretty well. This is not a high RPM motor that is going to see a lot of track use and it will driven but probably not more than 10000 miles per year -- it will last for a couple of years anyhow.
Keith: I think I know what you and I will be doing next Thursday night. The beer is in the fridge!
Thanks everyone for the help and advice and I will keep you posted.
Rich
2004 GT-3
1969 911E
1988 944 Turbo
1990 BMW 325i
2001 BMW Z3
Old 04-11-2003, 09:02 AM
Author of "101 Projects"
Wayne 962's Avatar
keitho64 - EXCELLENT POINT! I had completely forgotten about that. Since we now know the 'history' a bit on this motor, let me suggest something else.
It is possible that the rebuilder went ballistic on this engine and didn't know what they were doing (why wasn't the engine ever installed?) If they had my book, they would have known what to do and what not to do <- subtle plug.
Anyways, perhaps the machinist/builder tried to increase the compression ratio a bit too much, or machined the case incorrectly. Taking too much material off of the heads, or machining the spigots of the case will move the cam towers closer to the case and make the chain loose. The solution is to remove a link and use a special sprocket (photo of this in Bruce Anderson's book) that is a bit smaller.
I wonder if this is the problem. Now, I'm curious, and I don't want to wait three days to find out, rats!
-Wayne
Old 04-11-2003, 10:37 AM
keitho64's Avatar
Wayne - I am sure Rich would welcome you coming to his house to resolve this while he is on vacation. Besides, I will be on the left coast next week and I would get to meet you.
Anyway, I think I will be involved in this soon since Rich is being kind enough to let my family stay at his house and trash the place. We will put our heads together (I know bad Pun) and see what is going on.
Any suggestions as to how to tell if the heads have been milled without removing them? Is it possible the original tensioners were modified if this is what is going on? I just love solving mysteries.
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 04-11-2003, 10:59 AM
Wayne:
I'll leave the key under the mat if you want to come down and look at it or you are welcome to join Keith and I next weekend (late night) to check this out. I want to go home and look at the intermediate shaft but darn work is getting in the way again.
How would I check to see if the heads were milled?
I have an idea for a product for Pelican -- an inexpensive flexible fiberoptic borescope for looking into the engine or transmission. I have been on the verge of asking doctor friends if they have an old one somewhere. It would be so great because you could just insert it into any little hole in the engine and transmission (they have little headlights on them) and snake it around and see with your own eyes (or on a video monitor) just what is in there without taking it apart. This place has an interesting product for about $250: http://www.tooldesk.com/shop/borescope1.wml
Again, thanks for the help.
2004 GT-3
1969 911E
1988 944 Turbo
1990 BMW 325i
2001 BMW Z3
Old 04-11-2003, 11:43 AM
Wayne 962's Avatar
Do you mean this borescope, which we sell in our TOOLS section:
http://www.pelicanparts.com/catalog/shopcart/DWKS/POR_DWKS_toolsG_main.htm
I have seen both of these, and they work great!
Okay, how can I get people to find stuff in our catalog easier? This is a huge problem!
-Wayne
Old 04-11-2003, 11:54 AM
keitho64's Avatar
Rich - Wayne is tempting you with the order. Will you have one of these before I get there?
Keitho64
05 GTO
00 911 C2
64 Corvair
Old 04-11-2003, 12:08 PM
Somatic Negative Optimist
Gunter's Avatar
Slipping on a new chain with ML (as long as the closed end of the ML points in the direction of travel) is o.k. but........After so many miles, the chain sprockets on the intermediate shaft have worn along with the chain. The new chain will have the same pitch, but no wear, therefore exacting a different force on the teeth of the sprockets, especially since the I. S. sprockets are the drivers. In industrial high speed applications, we prefer to use new sprockets with new chains for that reason. Some of you who have used new chains, but not new sprockets, may find the tips of sprocket teeth on the bottom of your sump. Have any of you had this experience? Wayne or J.W., have you seen this happen?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-11-2003, 12:34 PM
tiorio's Avatar
-Wayne
I REALLY hate to say this, but the best way would be to put out a paper catalog. People spend a lot of time browsing physical catalogs and they use computer based catalogs to find specific items, not to simply go from page to page looking at the stuff. Therefore if they don't automatically associate Pelican with tools (in this case, the association is with parts) browsing the Pelican is how the association would be made.
The other way is the BBS. You just let a bunch of us (like me) know that the tools section has even more than I thought. Now I have a better idea of when to go to Pelican for specific tool searches.
My .02 from the :30 commericial and advert. world...
-Todd
'89 930, '97 TLC (Toyota Land Cruiser), '96 T-100pick-em-up
'95 BMW R100 GSPD (gone but not forgotten), '07 BMW R1200GSA
Old 04-11-2003, 12:43 PM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
-Wayne
What you need is a search button for catalog as convenient and easy as the quick reply box is on these pages. If you had such a thing, we could type it in right here and look.
-kb-
Old 04-11-2003, 02:29 PM
Wayne 962's Avatar
Those are good suggestions. I did add the search field to the top of this forum, and I also fixed that search bug. It had been on my list to fix for quite a while, but you know how these things get pushed aside when there are cooler things to work on (like the Engine Rebuild Wizard)...
-Wayne
Old 04-15-2003, 04:03 AM
Rich,
I guess I jumped into this a little late, but here are my observations.
How does one tell how much material has been removed by machining (heads, crankcase, cylinders, etc.)? All of these can be machined as part of the prep for assembly. There could also have been previous attempts to increase compression ratio by flycutting the head gasket surface and trimming the cylinder heights as well. All of these machining operations, as Wayne points out, positions the cylinder head/cam housing closer to the center line of the engine resulting in increased chain slack.
When this happens, the camshaft is no longer centered in the stock chain box opening. This will make it difficult to install the O-ring assembly. If somehow installed despite this misalignment, it may eventually create an oil leak path. To compensate for the repositioned cam location, the chain box-to-crankcase mounting surface should be machined an identical amount that was machined from the aforementioned cylinder heads, cylinders, etc. Now what?
Now you have a chain that has more slack than a stock engine. As Wayne also mentions, you can install a custom cam idler sprocket to bring the idler arm back into the correct operating position. However, the sprocket must have a larger diameter than stock (as opposed to a smaller sprocket wheel).
Let's assume the chains (new) and sprockets are in full engagement, the chain boxes are properly machined, oversize idler sprockets are installed and the chain is still too long. Others may weigh in here with different opinions, but I'd try removing a link from the chain, then reassemble (probably with the stock idler sprocket). As long as the proper valve train geometry is maintained, albeit with one less link, this should work. Let me add a caveat in that it's entirely possibe I'm overlooking something.
As to the question of knowing how much material was removed from the cylinders/cylinder heads and crankcase spigots via machining - you can measure the thickness of the chain box wall where it bolts onto the crankcase. If the cam is centered in the opening after all the previous machining, then the chain box mounting surface has been machined a like amount. Compare the thickness of the chain box "wall" with that of a stock, unmachined chain box. B.A. recommends no more than 0.040" be removed from the cylinder/cylinder head "stack". You may find your measurement is more than this coupled with a well-worn chain.
BTW, in case you already found the easy fix, disregard the above.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 04-15-2003, 11:10 AM
Well, I just thought I would update this thread, THANK ALL OF YOU GUYS VERY MUCH FOR YOUR SUPPORT AND IDEAS and let you know that IT IS ALIVE!
KeithO64 was visiting this weekend and we spent Tuesday night looking at the problem. We looked and looked and turned and inspected and checked and watched and turned and just came to the conclusion that there was no way in the world that the chain was off the intermediate shaft sprocket. We also noted that the intermediate shaft gear was brand new, so somebody had taken some effort to rebuild this “mystery” engine. So, we looked in Wayne’s book and compared the pictures and noted that the earlier cars did not have this little lip (see yellow box in picture below) that the sprocket was hitting. Then we noticed that the chain boxes had a 930.xxx part number. We checked the other two engines I have and just like the book, there was no lip like this in the chain boxes. Since I have no idea what function this could serve (maybe strengthening for the air conditioning mounting???) and was clearly not necessary, we did what any good hot rodders would do and got rid of it.
We plugged all the passages with paper towels and Keith ground off the vertical part with a sanding roll on a line all the way to the front of the chain box. He removed material on a line about where the yellow vertical box line is in this picture. A shop vac and lots of Gumout to clean things out and it looked pretty good and there was no clearance problem anymore. We buttoned up the rest of the things on the car and the next day (the neighbors would not have appreciated a car with open exhaust at 3:00AM) and on the second turn of the key, the engine popped right over and ran great with no leaks. Keith set the timing at Z1 and it idled fine and the exhaust is clear! We toasted our success with a couple of German beers but unfortunately Keith and his family had to leave. It is just going to need some fine tuning (wife’s book club tonight) and it should be on the road soon. What a relief.
I have no idea why this was a problem on this engine. On close inspection, the chains appeared new. Maybe the heads have been milled or something that caused this problem, I have no idea. However, I just wanted to let everyone who contributed their thoughts to this project or who might run into this rather weird problem that there is a potential solution and it seems to work fine. I will need to get it running, give some driving impressions and perhaps get some G-Tech data for discussion.
Thanks to everyone again for their help, especially Keith for taking time out of his vacation to work on this.
Rich
2004 GT-3
1969 911E
1988 944 Turbo
1990 BMW 325i
2001 BMW Z3
Old 04-23-2003, 02:59 PM
i thought that the tensioners were extended as far as they could extend, and there was still chain slop. what about that? that shelf has never caused a problem for me.
206 637 4071
Old 04-23-2003, 03:04 PM
Wayne 962's Avatar
Yes, I don't agree with your analysis. I'm with JW on this one. I've never heard of these clearances being a problem. I would not drive the car until you figure this out, as this can destroy your entire engine. The angle of the chain tensioner with the sprocket holder looks too severe...
-Wayne
Old 04-23-2003, 03:25 PM
ruf-porsche's Avatar
Have a master chain setup on my twincam Lotus, haven't broke, but that hasn't stop me from tagging a few valves. Unlike the newer engines, or an old porsche engine, the chain tensioner on a Lotus twincam must be adjusted every 3,000 mile manually, no hydraulic tensioer or self adjusting spring tension, just a screw and a lock nut.
Lotus must have brought the chain from a english bicycle manufacturer, it only A SINGLE ROW CHAIN, NOT A DOUBLE.
Old 04-23-2003, 04:25 PM
Even though I rebuilt both of my Lotus engines more time than I care to remember, I never did a complete tear down on a 911.
I was just wondering if the chain for the left cam is the same as for the right cam? Since the tensioners are not the same is there also a difference in the length of the chains?
Just thinking, but I try not to do that too much.
Old 04-23-2003, 05:21 PM
