Brake bleeding tools?
Going to be fitting a new master cylinder to the SC and figured i'd pick up some tools to make life easier.
What have you found that makes life a lil easier?
Old 04-19-2020, 03:48 PM
Motive power bleeder.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-19-2020, 03:50 PM
Home of the Whopper
I use this:
Old 04-19-2020, 04:43 PM
Second on the motive power bleeder. However, you are going to need to “plug” the vent side on the master cylinder reservoir.
I am not sure exactly sure what BK911 does with that connection to an air compressor, perhaps he will expound so that .... we can perhaps make an annoying job more easy(???)
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html
Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things.
Old 04-19-2020, 06:00 PM
Home of the Whopper
Hook the air compressor to the brake fluid reservoir vent opening with about 5 psi.
Works just like a motive, but only costs <$5.
Old 04-19-2020, 07:10 PM
High Life's Avatar
Then do you just crack the bleed valve on the caliper (left rear, right rear, left front, right front) and wait for fresh fluid at each caliper?
Do you have someone watch the reservoir as your bleeding - or is there a trick for that?
1981 911SC
Old 04-19-2020, 07:20 PM
Home of the Whopper
I use a dump bottle that's smaller than the reservoir.
1. Set compressor to 5psi.
2. Connect hose to reservoir bleed.
3. Fill reservoir, close cap tightly.
4. Connect air quick connect.
5. Crack brake bleed.
6. Close brake bleed when dump bottle fills.
7. Disconnect quick connect fitting.
Repeat steps 3-7 until fresh fluid leaves each caliper.
If you're bleeding a dry system you need to pay attention to the reservoir level. I use a flashlight pressed against it.
Old 04-19-2020, 07:38 PM
Always Be Fixing Cars
You can use the motive wet or dry with good and bad aspects to both.
Wet = full of fluid = no way to run dry (unless you go thru all the fluid in the Motive, duh). Downside is typically a bunch of wasted fluid and generally more handling of brake fluid, chances for spills etc. I do this for major flushes or first fills.
Dry = motive is only providing pressure. Chance to run dry but less mess if done right. I do this for "normal" bleeds.
Get a proper fluid line clamps for the over flow, don't damage it with vise grips etc. I use https://www.amazon.com/gp/product/B002YKHRUK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 04-19-2020, 07:47 PM
HarryD's Avatar
If you are just flushing the lines to replace old fluid with new, you only need to move about 170 ml from the farthest wheel cylinder (less volume is needed for the others since the lines are shorter - duh).
How do I know this? Back when Gold and Blue ATE was available, I would switch between the colors and that was the volume that consistently resulted in a full color change.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-19-2020, 09:17 PM
I purchased a Motive pressure bleeder based on recommendations on Pelican and have been very happy with it. I use it dry, which takes longer but requires much less cleanup. I have accidentally sucked air into the master cylinder once and find it best to refill the reservoir after every wheel. It's a slower process but still pretty quick.
Regarding clamping the overflow, I remove it instead. I attach a small piece of tubing that I clamp instead.
My thought is it is simply less wear and tear on the overflow hose.
Old 04-20-2020, 08:07 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
And a 9/11mm flare wrench.
And a catch bottle.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 04-20-2020, 12:08 PM
