Carrera front hub/rotor bolt circle question
Can someone confirm that the bolt circle for the bolts that mount the hub to the rotor are on a 126mm circle. I believe I found this on a spec. sheet somewhere but can't dig it up and want to make double sure. I am having some custom rotor hats made so measure three times cut once.
For extra credit, what is the bolt hole size? Thanks in advance as always, Bill |
130mm according to this
https://www.wheel-size.com/size/porsche/911/1969/
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
RETIRED
5x130, our host carries the correct nuts. I prefer open top steel as opposed to the alloy nuts.
The alloy ones tend to fracture and you a hell of time getting the remainder off w/o fubaring the wheel. AND FOR GOD's sake don't use wheel locks.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Sorry, I didn't mean the bolt circle for the wheel bolts, which is indeed 5 x 130mm, but the bolt circle for the bolts in the inside of the hub that mount to the brake rotor.
Bill |
RETIRED
Maybe if you told us what is up? Did you lose them? You could always pull annother wheel and remove the bolt in question and measure it.
Bill
I measured this hub. Rough measurement.
That bolt circle is 126mm. Between centers 74mm, that gives us 126mm diameter.
It uses 8 x 22 hex head bolts
Thanks!!! That's what I needed.
Bill |
