Thermoswitch Part Number
Sorry to ask something I know has to be in the archives, but after 30 min. of searching, I give up.
Can anyone tell me the part number for the lower temp. (210 F) thermoswitch for the Carrera-style external oil cooler? One post said its a Sachs part used on a BMW.
Thanks,
Scott
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 01-11-2005, 06:23 PM
82C: BW-61-31-1-364-272-82
91C: BW-61-31-1-364-272-91
99C: BW-61-31-1-364-273
Old 01-11-2005, 09:09 PM
Scottsdale Arizona USA
61 31 1 364 272 82 FAE
Auxiliary Fan Switch - (82 Deg. C) - FAE
Note: White Top (2-Prong Thru 08-87). Includes Sealing Ring.+ Replaces PN: 930 606 118 00 - Temp Switch On Oil Cooler Front Right - 911 / 930 = 118Deg. C (244.4 F) & 900 123 009 30 - A14x18 mm Sealing Ring ** Use as replacement for right side cooler fan to come on a lower temp or as a port plug for additional cooler.
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design
+1 (844) URO-PART // modepw@europartswest.com
Old 08-28-2017, 01:02 AM
rokemester's Avatar
Does anyone happen to remember how they hooked up the temp sensor? The old sensor had a single wire and a ground wire went to a ground lug on the cooler. Does it matter? Two leads right to the new two spade thermocouple? Or do you need a jumper to the ground spade? Thanks!
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 04-23-2020, 04:16 PM
I crimped the second wire to a lug and put it under an existing screw as a ground.
Scott Wilburn
1998 M3
1984 308 QV
Old 04-23-2020, 07:12 PM
rokemester's Avatar
Thanks. Do you have an OEM thermoswitch with a single connector, or a dual prong FAE switch like pictured on this thread?
Northeast Ohio
1966 VW Beetle, 6V
Old 04-23-2020, 07:47 PM
I have a 2 pin. It is a BMW part I used to get a lower set point.
Scott Wilburn
1998 M3
1984 308 QV
Old 04-23-2020, 07:52 PM
rokemester's Avatar
Hey Scott, do you have an open spade on your switch?
Northeast Ohio
1966 VW Beetle, 6V
Old 04-24-2020, 04:22 AM
It has been many years, but as I recall it has two male spades. I crimped a female spade onto the existing wire for one connection. I made a short wire with female spade on one end and round lug on the other for the second connection.
Scott Wilburn
1998 M3
1984 308 QV
Old 04-24-2020, 07:35 AM
rokemester's Avatar
Yes and once you wire that puppy up it’s super hard to see what you did! Sounds like you made a little jumper wire from 2nd lug on switch to the cooler ground lug.
Northeast Ohio
1966 VW Beetle, 6V
Old 04-24-2020, 07:55 AM
