Unhappy Turn signals not working
I have a 996 (2001) that the turn signal lights are not working, but when I turn on the
flashers they work. I have checked all the fuses with none of them burned out.
What can be the problem? Do the turn signals and the flashers work off the same relay?
Old 04-26-2020, 10:06 AM
7783911's Avatar
have you checked grounds?
Old 04-26-2020, 01:29 PM
996 turn signals not working
Wouldn’t the ground be the same for the turn signals and the emergency flashers?
Old 05-01-2020, 12:18 PM
Probably in the turnsignal stalk. Try wiggling it arounda little more than usual to see if you can help it make contact. If so you will need to replace, or remove and bend the contacts...at least that is how the older 911s work.
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 05-01-2020, 12:49 PM
