inside case concern?
Should I be concerned about this?
1987 Porsche 911 Carrera Coupe
Old 05-02-2020, 11:51 AM
proporsche's Avatar
no you should not every engine case has this ..tube for oil supply to oil press regulator release valve.........
here is some reading
Ultimate Oil Pressure Relief Valve Thread
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-02-2020, 12:16 PM
Ivan
Thanks Ivan.
I was worried that it was peeling and shards of metal could come loose. Wasn't sure if there was some coating that has peeled away and could cause corrosion.
Old 05-02-2020, 02:38 PM
