inside case concern?
Should I be concerned about this?
1987 Porsche 911 Carrera Coupe |
no you should not every engine case has this ..tube for oil supply to oil press regulator release valve.........
here is some reading Ultimate Oil Pressure Relief Valve Thread Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I was worried that it was peeling and shards of metal could come loose. Wasn't sure if there was some coating that has peeled away and could cause corrosion.
