Rear Bottom Engine Mount Studs?
Hi Peeps. 3.0 race case.
I need to replace these threaded studs with longer ones in order to mount a tow hook, a GT3 muffler carrier and a mount plate for a Lifeline Rain light.
Any trick to removal? Can i simply Vice grip the crap out of them and back out? ( of course, with the engine supported from bottom).
thanks very much.....
frank
Old 05-02-2020, 03:15 PM
You should be able to double nut them out.
By 3.2 the factory used 10mm bolts
Bruce
Old 05-02-2020, 03:48 PM
Picture will help........
Frank,
Could you post a picture? Thanks.
Tony
Old 05-02-2020, 04:51 PM
Walt Fricke's Avatar
He's talking about these studs. That's where those tow hooks attach.
Old 05-02-2020, 10:45 PM
Thanks Walter. Yes those. And nice weight reduction! BTW. 10mmx1.5 thread. I think i can just double nut them to back out. Maybe use a propane torch on the block. thanks everyone.
Old 05-03-2020, 07:03 AM
AutoBahned
RWebb's Avatar
nice holes Walt!
Old 05-03-2020, 01:50 PM
studs
They are 10 x 1.5.Usually never a problem with double nut removal.Fred
Old 05-03-2020, 02:01 PM
thanks fred and all. was really quite easy.. not sure why i was so hesitant....
Old 05-03-2020, 06:08 PM
