-   -   Need some input -> Problem with 3.2 transplant going lean and misfiring after two min (http://forums.pelicanparts.com/porsche-911-technical-forum/1059924-need-some-input-problem-3-2-transplant-going-lean-misfiring-after-two-min.html)
proporsche 05-14-2020 03:06 PM
sweet jesus ,it is you Loren alias dave still after all these years , big PITA and arrogant ..why do you even posts your brain tumors here??beats me..
Ivan
live is about communication and you do not have those skills ,ever ..if you have nothing good to say why do you talk --write...
mysocal911 05-14-2020 03:16 PM
Originally Posted by ischmitz View Post
that’s why Bosch had to employ the P&H topology.
Originally Posted by mysocal911 (Post 10865464)
Many who have reverse engineered both the Porsche & BMW Motronic DMEs of the '80s, have learned that Bosch designed Motronic DMEs
for both low & high impedance injectors. The standard BMWs, e.g. 535s, used high impedance injectors. The M3/M5/M6 engines used low
impedance injectors like the 911 3.2, and as a result had basically the same DME ECU design but a different EPROM.
An english reading comprehension problem, right?
Wayne 962 05-14-2020 03:21 PM
Originally Posted by mysocal911 (Post 10865430)
Most who have worked on engines that use an AFM as an input for load, understand that it's likely that the AFM has been re-adjusted
over time from the factory setting, e.g. for more power. This usually results in an over-rich running condition when warm. Knowledgeable techs
when having rough or rich running conditions, typically check the spring tension of the wiper by moving it at the problematic RPM,
and noticing the effect. The typical AFM wiper spring tension setting is set at 2K RPM for a 1.0 - 1.5 CO without the O2 sensor,
with a warm engine.
Yes, that's good advice. I've been semi-reluctant to remove the AFM because there was a previous vacuum leak here (small) that I patched with some sealant (now no leaks), and also because all the tests I performed on the output of the air flow meter seemed to reveal no issues. BUT, at this point, I'm close to getting ready to pull it to take a look.
-Wayne
Techno Duck 05-14-2020 03:30 PM
-Wayne
Whatever electrical testing was done on the AFM does not take into account the spring tension on the door of the AFM. Output voltage will show normal, but the amount of air its actually metering will not match what the DME thinks its getting. Spring tension on the barn door of the AFM can only be truly tested using a flow bench and knowing whatever correlation between voltage output and CFM.
One can reasonably adjust the AFM spring tension by checking AFR with the engine under load at various throttle positions. As i mentioned on page 1 of this thread, this is a dangerous way to do it. Also like i mentioned, this is how i figured out what was wrong with my car.
ischmitz 05-14-2020 03:40 PM
Jon,
good points. Also, the bypass screw on the AFM essentially influences where the barn door ends up under idle conditions. So at a given idle with the screw all the way tight and the passage blocked the door deflects more -> mixture richer. If you back out the screw air can go through that bypass and the door is closer to its mechanical rest position -> mixture leaner. The DME only sees the electric output equivalent to the door position. This is how idle mixture is set on the 3.2
I don't know how much you'd have to mess up the spring or how much impact that has relative to this adjustment. On a virgin AFM the rule of thumb is to tighten that screw all the way and then back out 4 - 5 turns.
Techno Duck 05-14-2020 03:59 PM
ischmitz, i looked at some old pictures from when i was messing around with this. The clock spring on my AFM was adjusted aproximately 8 teeth from where i believe it was 'factory' set. There was a scribe mark on the wheel that was probably only smart thing the person that adjusted the AFM in the first place did. Car ran incredibly lean, to the point of audible knock. Despite fixing this, i think the damage was done, i have no idea how long the car was driven like this. End result, i foot the bill to make it a 3.4L "while i was in there".
I also think knowing what the true cold start AFR is will be a helpful clue to determine what is going on. As Wayne mentioned many times, it runs fine at cold idle. If cold idle is at 15:1; its going to idle ok, but will lean out even further as the car warms up; probably beyond what the O2 sensor and DME can correct for. I looked a few times to see if that question was ever answered, but too much stuff to sift through.
ischmitz 05-14-2020 04:34 PM
Yes - makes a lot of sense. Fact is that messing with the spring tension in the AFM is the WORST way to affect mixture. Completely uncontrolled and no way of knowing what you end up with. It may cover another issue (e.g. vacuum leak) well only to destroy the engine with this hack-fix. Your damaged engine is living proof of that. The O2 sensor system can only do so much before it gets to the end of it's rope. It was never designed to account for this kind of issue.
I am surprised the AFM bypass screw for setting idle mixture hasn't been discussed in more detail. Or maybe it was covered and I missed it in the flood of messages. I still think that is the single most impactful way to shift the idle signal from the AFM at running temps. At cold the CHT richens the mixture to the point of condensation on the intake runners and your engine runs essentially from that stuff. But as you get to operating temps that is going away.
Also as you go higher in load (barn door opens wider) that adjustment even if completely wrong becomes less and less meaningful in the overall picture. It just tweaks the response of the AFM at idle and running temperature and that is where he seems to have issues....
mysocal911 05-14-2020 06:12 PM
Correct!
Actually, you missed the point being made, i.e. using the AFM is a valid approach for troubleshooting fuel running problems,
once the initial spring setting is marked. The AFM is unique versus other load sensing devices, e.g. MAF/MAP sensor,
in that one can easily change the fuel mixture and determine how the engine responds and always revert to the original setting.
If the engine seems to be missing once it's warm or too rich, use one's finger to reduce the wiper position (no need to actually
change the spring setting). That will provide insight as to whether the rough running is air/fuel mixture related.
With regard to the air bypass screw on the AFM, it has little to no effect once the flap begins to move.
The only real effect it has is at idle! That should be obvious, once you relate the air flow from the flap
to the air bypass hole size.
ischmitz 05-14-2020 07:20 PM
Originally Posted by mysocal911 (Post 10865753)
With regard to the air bypass screw on the AFM, it has little to no effect once the flap begins to move. The only real effect it has is at idle!
Isn't idle where Wayne has issues? SmileWavy
Wayne 962 05-14-2020 07:28 PM
Okay, I have some updates from today, but I’m headed out for a bike ride very shortly, so I will briefly document them.
ISSUE #1:
I think I may have missed something obvious the other day – something that Steve W commented on back on Sunday. The cylinder head temperature sensor. I measured them after moments of running – I did not actually get under the car with my laser thermometer and *actually* measure the temperature of the exact sensor. This was a mistake, as I found some discrepancies. Kenny @ AutoWerkstatt loaned me a brand new Porsche head temperature sensor today, and I took it out and dropped it in (not fully submerged) into some hot / near boiling water, and I tested the resistance. Here are the findings:
NEW:
22 degrees C – 2062 ohm13.8
51 degrees C – 900 ohm
67 degrees C – 434 ohm
77 degrees C – 308 ohm
OLD (in car):
26 degrees C – 792 ohm
32 degrees C – 1023 ohm
36 degrees C - 365 ohm
43 degrees C - 421 ohm
47 degrees C - 154 ohm
50 degrees C - 185 ohm
Porsche spec:
0 degrees C – 4,400 to 6,800 ohms
15-20 degrees C – 1,400 to 3,600 ohms
40 degrees C – 1,000 to 1,300 ohms
80 degrees C – 250 to 390 ohms
100 degrees C – 160 to 210 ohms
130 degrees C – 90 ohms
So, the bottomline is that the sensor that is in the car is out of spec, by quite a bit. I made this mistake by not directly measuring the sensor temperature on the engine (one has to remove the large grommet covering the hole). Tonight I will replace the sensor. I think this is contributing to the problem, but not 100% the problem.
http://forums.pelicanparts.com/uploa...1589508756.JPG
ISSUE #2:
When I saw Steve W. today (he lent me a 3.2 fuel rail setup), he specifically mentioned the airflow meter and wanted to make sure if I had checked to see if it had been “messed with”. Since I recently sealed all of the vacuum leaks up, I didn’t really want to remove it, but I think I will tonight to take a look. I found something odd with the air flow meter today. Reminder – I checked the flapper to make sure there were no flat spots on it – I’ve now checked it multiple times, and I still think it’s okay. However…
I read this today, and thought, “I wonder if the air flow meter flap is opening at idle”:
Indeed. But I found that when running the car at idle, the air flow meter flap is opening. I confirmed this through my oscilloscope which shows the flapper moving when we start the car. Here’s the video:
<iframe width="560" height="315" src="https://www.youtube.com/embed/7Hc0CeVMFgw" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I didn’t even think to check the air flow meter to see if it was opening at idle. There’s no test for that listed in the factory manuals. It may be opening incorrectly because it's been "messed with", or it may have something to do with the airflow in the altered boot in the manifold (technically/theoretically it should not, but with fluid laminar flow, odd duck things tend to happen sometimes!).
Thoughts?
-Wayne
ischmitz 05-14-2020 07:48 PM
At the danger of sounding like a broken record:
The amount of air needed to idle is the sum of what passes through the adjustable bypass channel around the barn door and what has to pass through the barn door thereby deflecting it. By adjusting the cross-section of that bypass with the allen set screw you effectively vary the position of the barn door at idle. At idle the total amount of air ingested into the engine is comparatively small to when the engine is under load at elevated RPM. That's why this adjustment mostly impacts idle mixture.
Techno Duck 05-14-2020 08:03 PM
This is also why i asked if the silver plug that covers the adjustment screw was still on the airflow meter. The plug has to be drilled out to be removed.
mysocal911 05-14-2020 08:47 PM
ISSUE #1:
NEW:
OLD (in car):
Porsche spec:
Another waste of time and parts! As was mentioned before, once the sensor gets below 300-400 ohms it has basically NO EFFECT!
When the engine is warm, just bypass it with a paper clip if you're concerned. The only problem with the original sensor is that it's on the
low side affecting the cold running mode. You don't have that problem. The ONLY function of the temp sensor is for cold starting and running!
So what! It still may have the spring adjusted incorrectly, causing a too lean condition when warm, your problem (remember).
Right, it always moves when there's intake vacuum. Hardly any great news.
Then move the wiper when running the engine and see what happens!
Bottom line: The 911 3.2 system is not that complicated!!!!
mysocal911 05-14-2020 08:56 PM
The thread has gotten so long, who knows what the real problem is now, given all the parts changes.
It's never been stated, or I missed it, what happens above 1500-3000 RPM.
From the 1st post:
Here is the issue: When you start the car up, it runs fine for about a minute or two. The idle goes up to about 1,100 or so. Smooth running, no misses. Air/fuel mixture is rich (haven't set that yet) and seems within range). Then, after about a minute or two, the idle drops down to about 850 or so (where I set it), and then the car goes lean (to about 18 or so air/fuel mixture) and starts missing. If you rev the engine just a little bit off of idle, the air.fuel mixture goes straight to 14.7 or so, but the car is still flubbing / missing at this point.
Since the car runs perfectly fine for a minute or two and then all of a sudden starts to flub / misfire, it would seem to be a fuel injection problem for sure (not a mechanical or ignition problem). I replaced the plugs, cap, and rotor regardless because the car was stolen and sitting around for a long time, so who knows what happened to it, etc.
It doesn't help when all the running modes aren't fully indicated (posted).
Wayne 962 05-14-2020 09:08 PM
Yes, the car idles terribly after about two minutes, and then also misses in the 1500-3000 range...
-Wayne
Wayne 962 05-14-2020 09:13 PM
Idle is really bad. But also missing in the 1500-3000 rpm range...
-Wayne
Wayne 962 05-14-2020 09:46 PM
Took off the air flow meter - someone definitely has been messing with it, and it doesn't appear that the wiper has been placed into another position. Is the only way to have this checked / fixed is to send it off to a rebuilder that will be able to calibrate it? I've heard that Bavarian Restorations in the Bay Area has a decent reputation?
I knew getting this thing running again would be a major pain.
-Wayne
http://forums.pelicanparts.com/uploa...1589517986.jpg
Wayne 962 05-14-2020 09:48 PM
Yes, I've been using the screw to adjust the air bypass valve...
-Wayne
Techno Duck 05-14-2020 10:52 PM
The wiper track is heavily worn around the idle location for the AFM. Have you adjusted the wiper arm so it touches a good spot yet?
Personally, i would find / borrow a known good AFM and retest.
Steve W 05-14-2020 11:04 PM
So here's probably the major cause of your problems. On a scale of 1-10, with 10 being the worst I've ever seen yours is probably a 9, maybe even a 10. The carbon has worn down to the substrate, and you can also see a shadow of it at 15% in, where it may be the cause of the miss around 2-3000. There's almost no V out there which would cause the mixture to go very lean, while ignition timing would also be thrown out of wack because the DME would think there is little to no load on the motor. You can try and renew it by repositioning the wiper tip inward on fresh material, but you also face the need to check and probably recalibrate the spring tension as I previously described to you. I would not go to any aftermarket 'recalibrator' or source any aftermarket 'rebuilt' unit. Those have all been nothing but problems and severely miscalibrated, usually so rich the car ends up with a different problem that is insolvable. Or you can try and source a good used one, do an exchange with Porsche, or get a used one from a 964, from where Singer sends all their take off parts.
http://forums.pelicanparts.com/uploa...1589522386.jpg
mysocal911 05-15-2020 12:00 AM
You know all this stuff too. You did a lot of work on your 964 engine! It shouldn't take this much effort, right?
Wayne 962 05-15-2020 01:25 AM
I saw that, and it looked a bit worn. But I did test it and it tested perfectly fine using the oscilloscope:
http://forums.pelicanparts.com/uploa...1589530663.jpg
Your suggestion regarding the Singer take-offs is a good one. I'm assuming that the guy with all of the Singer parts is this guy?
https://www.ebay.com/itm/Porsche-911-964-C2-C4-OEM-Bosch-Air-Flow-Meter-Part-0280203023-96460605000/252081028870?hash=item3ab1333f06:g:aWkAAOSwgQ9V6g~ I
http://forums.pelicanparts.com/uploa...1589530792.JPG
I mean, who really has 76 of these units, unless you've been buying them off of Singer? He's also located right here in SoCal -> two pretty big clues there.
Tomorrow I will readjust the wiper on there and button the unit back up. Pretty disappointing, as I'm quite sure that this unit is not the one that I gave with the engine (that only had 65,000 or so miles on it). In the meantime, I will try to source a new AFM that hasn't been messed with.
-Wayne
proporsche 05-15-2020 01:38 AM
Wayne i`m a little too far but i can give you a unit for free -i have 4 - but it will take a little time with the post....let me know if you like it later ,problem ,you would just pay for the postage....i guess it would take a week with DHL?
Ivan
Wayne 962 05-15-2020 01:51 AM
Ivan
Wow, that would be great, that will help with comparisons! Just sent you a PM.
-Wayne
FrankM_ 05-15-2020 03:58 AM
Ivan
Proporsche,
I have the same issue : AFM tracks worn to substrate. I have tried retracking them and it 'looks' Ok on the scope but with the engine running there are dips and peaks (even on idle) resulting in a small hesitation.
Due to COVID, I am unable to do a test drive (it is still forbidden to drive classic cars in BE 'for leisure'). If the retracking doesn't work out, I will be looking for a replacement unit soon.
If you decide to sell any of the units, plz contact me.
@SteveW : I see that the output of the AFM (pin 7 ECU) goes straight into the multiplexer and then the A/D converter. So somewhere in the EEPROM there must be a mapping table for the input ? Can this be used/remapped to make the ECU work with the 'aliexpress' replacement boards for the AFM ? Or is it impossible to recalibrate perfectly ?
Kind regards,
FrankM from Belgium
john walker's workshop 05-15-2020 04:16 AM
I might have one also. Did mention that in post #8.
mysocal911 05-15-2020 05:43 AM
Kind regards,
FrankM from Belgium
Actually, what's typically used is an EPROM (UV) and not a EEPROM (flashable).
Yes, it can be re-coded if you disassemble the original Bosch EPROM code and re-write it in 8051 assembly language.
Also not that difficult if you have the Intel 8051 compiler and can write C code. If you have access to an old PC with DOS,
there's an assembler in it you can use to write the code in assembly language. Good luck!
wjdunham 05-15-2020 06:40 AM
Steve, I was not aware that the 964 unit is a drop-in replacement? Is this really the case? And yes, Autobahn in LA is where all the Singer take-offs go, I bought some 964 calipers from them. Nice guys and they are willing to deal on the prices somewhat
Bill
uwanna 05-15-2020 08:56 AM
-Wayne
Just noticed something different with the 964 AFM, although I don't know if it's
really that important. Had the cover off my 964 AFM and noticed it has a set of three contacts on the copper wiper unit instead just two on your 3.2 AFM. I know the two units are interchangeable, but there is that subtle difference.
Three contacts surely offer better redundancy than two.
Wayne 962 05-15-2020 10:44 AM
Can you post a photo of that? I don't think I've seen a photo of one before that has three contacts?
Thx,
Wayne
Wayne 962 05-15-2020 10:53 AM
I tested the AFM tracking on the oscilloscope three or four times, and I didn't see any issues with drops. However, I did see some "noise" on the output while the engine was running. Frankly, my gut is that this is not caused by the resistance strip, but is caused by some type of noise coming from somewhere else. If it were from the resistance strip, then I would think we would see consistent drops or spikes in the voltages (not both):
<iframe width="560" height="315" src="https://www.youtube.com/embed/Tx-ElHkZVGo" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I'm not sure how susceptible the ECU would be to noise in the AFM? I've never seen another scope trace of an AFM while the engine is running, so I don't know if this is typical / normal, or if this is an issue?
Thoughts?
-Wayne
GH85Carrera 05-15-2020 11:14 AM
Wayne, this thread will be a gold mine to future trouble shooters. And somehow it makes me feel a little better as a guy scratching his head when my 3.2 runs a little or a lot funny. After 25 years of driving my 911 I have come across most issues and helped fund your hobby with a lot of parts buying.
You are way more experienced than most of the other guys posting on Pelican. And some of the top experts have chimed in. I am following along to see just what is the culprit. My coil caused me some real headaches, and until I replaced it with a old black Bosch coil did that issue go away. You have replaced the coil and tried all the logical things.
Good luck finding that gremlin, and I look forward to seeing the solution and your cool 914 back on the road.
FrankM_ 05-15-2020 11:27 AM
Thoughts?
-Wayne
Mine has spikes too, but also slight hesitations in idle...
https://youtu.be/C2qnNGzoXrs
uwanna 05-15-2020 11:35 AM
Thx,
Wayne
this my 964 AFM
http://forums.pelicanparts.com/uploa...1589567673.jpg
Steve W 05-15-2020 12:01 PM
Thoughts?
-Wayne
It's not just the lack of noise or spikes in V out, but the correct linear rise of voltage as the door opens, that was originally calibrated by Bosch when the meters were made. Your voltage curve is likely very much out of spec, both from the curve change from the track wear, and possibly a someone messing with the spring tension. From experience, what you have is responsible for a lot of problems such as you're having. You can try renew it, it only brings it back or closer to original spec, and certainly can't be any worse than it is now. The width of the wear spot on yours is alarming though, 3x thicker than what is normally seen, as the tips of the wiper are just a needle's width in contact. Either the wiper was moved around before, or the tips have flatspotted. If that's the case, you practically need to recalibrate the whole thing by monitoring AFRs while driving the motor under different loads and rpms to bring the whole thing to where it should be. In any case, if you decide to renew it, best is to reposition is as illustrated below:
http://forums.pelicanparts.com/uploa...1589570027.GIF
Move the tip inward maybe about 1mm, and angle the wiper tip to maintain the same angle it had originally to the carbon track. Also adjust the wiper pressure so it has just enough pressure to maintain contact, so as when it just makes contact give just enough pressure for the wiper to deflect another 1 to 1.5mm of pressure. Too much pressure accelerates wear of the carbon, which you don't want. The arm should be positioned a couple of mm higher up on the pivot hinge than before in order to allow the tip to come inward. If you have a contact enhancer, lube and treat the track with it. I always use a DeoxIT pen on those. But your meter could be at the point of no return. It's also a bit questionable that half your wiper tip is off track completely, as if someone loosened that philips screw and repositioned the angle more clockwise to address a rich issue. They usually should not be that far off track, and most of the time are usually all on the carbon track when parked.
Porsche superceded the AFMs on the 3.2s to a 964 part number. A few years ago, Porsche offered replacement AFMs on an exchange basis for something like $700. No idea who redoes them for Porsche. The 964 units do all have a triple tip wiper tip, along with a reduntant wire from the wiper arm to the copper wiper bridge contact above it to reduce noise and resistance. The triple tip AFM can be found on some of the later 89 3.2s. These units do seem for some reason to exhibit less wear over time then seen on the 3.2 units, most of the time they look really good. Whether the calibration is the same, I'm not absolutely sure. The last 964 unit I tested seemed to have noticeably tighter spring tension than the one on my 86, and the throttle response also seems to be not as sharp. I ended up recalibrating it, loosening the tension to be the same as on my 3.2, I forget but I think by about 4 or 5 teeth, which brought the response to where it was equal.
Autobahn is where a lot of the Singer parts get sold to. You could contact them directly and speak to Mike who's in charge of those parts.
Wayne 962 05-15-2020 12:07 PM
Originally Posted by uwanna (Post 10866689)
this my 964 AFM
I saw a fairly well-done video last night that showed how someone "updated" their AFM with an attachment wire very similar to the one shown on your 964 AFM. I thought it looked a little "ghetto", but now I see the same exact thing on your 964 AFM here! I wonder if this was factory, or if these were updated by someone at some time.
Actually, here is the video:
<iframe width="560" height="315" src="https://www.youtube.com/embed/Z-QlPtsjh7g" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
-Wayne
Wayne 962 05-15-2020 12:24 PM
Originally Posted by Steve W (Post 10866731)
The width of the wear spot on yours is alarming though, 3x thicker than what is normally seen, as the tips of the wiper are just a needle's width in contact. Either the wiper was moved around before, or the tips have flatspotted. If that's the case, you practically need to recalibrate the whole thing by monitoring AFRs while driving the motor under different loads and rpms to bring the whole thing to where it should be.Autobahn is where a lot of the Singer parts get sold to. You could contact them directly and speak to Mike who's in charge of those parts.
I agree - the strip wear seems to be thicker than every other photo I've seen of them. Seems likely that someone already messed with this, and moved it to a new spot (which is now possibly wearing).
I will try to move it to a new section and see if that makes a difference, while moving to get one of those 964 Singer take-off units. It is interesting that there was an original 930 part number that then got superseded to a 964 part number, but the internal BOSCH number remained the same on both of those units. Something is a bit odd about that - I'm quite familiar with the way Porsche performs supersessions, but not so much on BOSCH. The 3-contact 964 unit *should* be a separate part number if done "the Porsche way", as it's an updated (and presumably more reliable design). Also, in the back of my mind, I would think that the displacement increase of the 3.6 versus the 3.2 (more than 10% difference) would mean that the airflow would be greater through the 3.6 engine than the 3.2. That would mean that the effective range of the unit would be less for the 3.6 if the two AFM units were exactly the same (the flapper box would max out opening / pushing against the barn door screen sooner than on the 3.2, resulting in a more limited range of the box). If BOSCH increased the spring tension on the door to compensate, that would make sense, although technically that *should* not be the same part number. Who knows, it could be either one...
-Wayne
uwanna 05-15-2020 12:25 PM
-Wayne
As Steve W noted that wire seems to be part of a 964 AFM update.
My AFM came from a 10k mi unmolested 964 3.6 and was sealed as new.
Steve W 05-15-2020 12:38 PM
BTW if you ever fix this thing, the next thing you should address is the clusterfuch of elbows om your intake. From dyno testing every 90 degree bend kills power by 4 hp to the wheels, and the one from your air filter to the AFM is horrible, at least a 10hp killer!
Wayne 962 05-15-2020 12:48 PM
Ahh, the good ole days. Way back in high school I used to program in 6502 Assembly Language on the Commodore 64. I got so good that I used to write programs for RUN magazine at the age of 16. I even found a copy on the Internet!
http://forums.pelicanparts.com/uploa...1589572135.JPG
Gosh, things are so much easier these days with libraries, and modules, and apps, and graphical user interfaces, etc. And compilers!
As expected, *none* of the high school girls were ever impressed with *any* of this stuff...
-Wayne
