AC Question
I have been chasing a leak in my AC system and found it on the side of the compressor where the charge fittings bolt in. My question is when I disconnected the lines to remove the plate the lines did not have O rings on them, aren't these lines supposed to have o rings?
89 930 Cab Black 11 Cayenne |
Yes, there should be an O-ring there. And it takes very little torque to seal it. It is a large nut and very easy to over tighten.
![]() If you tighten it much at all, it will crush and cause this. I fought that leak once before.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Thanks. There is a new line on the low side put on prior to my ownership. I can't believe someone would install a new line and not put an o ring on it.
Stuff happens; we are humanish
Kuehl 1987 911 cab, modified https://griffiths.com/ |
Agree But the PO had all work done by "professionals" you would think an experienced pcar mechanic would remember to put the o-rings on.
Oh. Suddenly, all P Car mechanics are not human? Hmmm.. Interesting observation.
I guess the past 3 P Car Dealerships that serviced my various P car rides are filled with humans then. Cause none of them have been perfect. And, the past few P car Techs, each had over 30+ years of experience, who messed up things, are human too.
My first word in my reply was “agree” We do all make mistakes sorry if I offended you in any way I was only looking for clarification on the o ring question I thought maybe it did not use one in that location. PS you might want to find some new mechanics if they make that many mistakes
89 930 Cab Black 11 Cayenne Last edited by Mike80911; 05-06-2024 at 01:55 PM.. |
... .its always the "but" that makes me a non believer , lol
the.... Yeah, but I know, but I understand, but but but but
"If only installers read directions the first time, or the second, or the third time" Maybe then they would not forget the o-rings don't you agree?
This is a funny thread for me b/c I did just this, and Charlie found it. I installed every inch of a new AC kit from Kuehl, following his excellent instructions to the T, or so I thought. Since I didn’t own the vacuum pump, gauges, or know-how 15 years ago, and since I live about an hour from his shop, I decided to drop off the car at his shop for the inaugural purge and charge while I went golfing nearby. I came back at the end of the day and he informed me that he had to track down what turned out to be a missing o-ring. Duh. He very matter-of-factly said “You did a nice job. Everyone makes a mistake now and then”.
So this is Deja vu for me.
Ken 1986 930 2016 R1200RS |
Gilles RoW 88 Carrera coupé |
If it makes anyone feel better......I replaced every line on my 87 and did not have any leaks at all.
However, I did search for an hour for the non-existent fourth bolt on the compressor. It has four mounting holes, but Porsche only used three! I was close to ordering another one when I realized it only used three. |
#11 only 3 required. https://nemigaparts.com/cat_spares/pet/porsche/911/512u/813200/ Last edited by emac911; 05-07-2024 at 06:53 AM.. |
My bad. Was looking at stud labeled 2B with washer and nut 7 and 8 but they don't hold the compressor itself. Only the underside plate.
