Designer King
Will I need a larger battery for my starter and CR?
I have a modified 1980 engine which has 3.2L and a 10.3:1 compression ratio. I also have a high torque starter.
I would like to go to a Group 48 sized AGM battery to replace the current 49 lead acid one in order to save about 10-15 pounds. The car is used nowadays only in warmer temps, say above about 2C or so. What do you think. Can I go with the Group 48 AGM? Thanks.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Paul,
You should be fine . . . we use a garden tractor battery in our race car with 12.5CR 3.8L race engine . . .cranks great !! Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
The geared high torque (and lighter) starters really do the trick. What you don't get with smaller batteries is duration - if you are having troubles starting, you can't keep cranking for as long or often.
Caveman Hammer Mechanic
This^, if you want to insure great cranking replace your positive cable with a larger gauge cable, less amperage lost to heat. Add an extra ground strap, do everything you can to eliminate resistance.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
