Engine noise - intermittant clang
Hi Guys
I have a metal clanging noise which only happens after engine warms up (5mins)
seems random/intermittant, one comes then nothing for few seconds, then another, seems to happen more often as engine gets hotter. Then i switch off in case of damage.
also seems to be slight puff of smoke just after happens.
could this be valve to piston? Or maybe sticking valve?
i have had engine out for respray but also fixed an oil leak and whilst had cam chain covers off I did a minor adjustment on valve timing.
This seems to be happening evry time i have her running now. I have a video on Youtube:
https://www.youtube.com/watch?v=bIfI4BX_OFU&feature=youtu.be
Any advice appreciated!
ta Jon
Old 05-16-2020, 04:20 AM
The sticking valve is a good guess but doesn't sound quite right, at least on the video. I sounds higher up on the engine.
I would also check the Pulleys, fan belt, fan, and fan housing and alternator. The fan housing could have a crack.
A compression check would be a good idea. Possibly isolate a bad cylinder.
Best of luck,
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 05-16-2020, 07:59 AM
Any scuff marks at the bottom of the fan housing from the fan rubbing? Housings crack and belt tension pulls the alternator/fan down.
206 637 4071
Old 05-16-2020, 08:06 AM
proporsche's Avatar
it would be nice if you make a video from behind seeing the complete back..
from what i hear it could be inside your banana- muffler...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-16-2020, 08:11 AM
