-   -   My 3.2SS build. (http://forums.pelicanparts.com/porsche-911-technical-forum/1061335-my-3-2ss-build.html)
JackkTheMackk 01-07-2021 04:45 PM
Took the heads off and replaced the expandable tubes with gold porsche tubes. Everything is all back together. Next on my list is trimming and fitting the getty RSR shroud and mounting the MSD, coils, and fuel regulator in the bay.
Anyone have any input on a good fuel filter set up? Also scooped another project today. Never ends.
http://forums.pelicanparts.com/uploa...1610070191.jpg
Evan Fullerton 01-07-2021 05:16 PM
I'm really curious to see see what kind of power this thing makes.
3.2SS vs 3.3SS, straight cut vs. 964 steel intermediate shaft gears, and GT3 oil pump vs. Auto Verdi are decisions I have to make this year for my build...... and to get my 930 heads from my Girlfriend's in Germany to send to Xtreme once we all can travel again.
JackkTheMackk 01-07-2021 06:26 PM
Should be 260 wheels / 300 crank when finished based on similar builds.
Trackrash 01-08-2021 09:49 AM
Have you seen the Roadkill episode where they dropped a 440 into one of these?
JackkTheMackk 01-08-2021 10:32 AM
I have not. It’s a 1990 300GD from Spain, 5 speed manual. Cloth interior, no sunroof, and no rust. It has the NA 603 in it right now and i’m looking for a local OM606a turbo to swap in. The 603 is a little anemic with 113hp.. would love to get 200hp with turbo and just have something safe and reliable. First diesel so learning a lot as I dig into info on a swap.
targa72e 01-08-2021 11:35 AM
The roadkill episode was 440 into a Suzuki samari. The Mercedes 300GD kind of looks like a samari when there is no size context.
Pic of Samari
https://www.suzuki-forums.com/attachments/sam1-jpg.13237/
john
Trackrash 01-08-2021 11:41 AM
Pic of Samari
john
Had me fooled. :D
macssc911 01-09-2021 05:57 AM
That is about right on horsepower might be slightly lower but in ballpark
Nice looking work, it’s so cool how pretty the engine is during build almost a shame to have to run . Will be exciting any plans to take it back apart and blue print?
JackkTheMackk 01-09-2021 07:28 AM
Going off the build linked below, 300 should right on the money with my hotter cams and a few other things. No plans to take it apart till it needs a refresh, whenever that may be.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/758301-3-2ss-twin-plug-underway-3.html
macssc911 01-09-2021 07:43 AM
Hope you get, mine is built almost identical to that tread, your cams are probably hotter than my Elgin S , mine makes peak hp around 6800. My cams come in with carbs around 4000. I came in a little under 300 at crank, but I think I may need a little more carb fine tuning. Anyway know you will have fun with it
Gabe. 01-11-2021 07:37 AM
SO Stoked to see you getting your engine together after all this time.
That's awesome that you picked up a G-Wagen too. I was eyeballing them during the holidays. I think I'd go four-door but also be interested in something diesel. Excited to check it out.
Let me know if/when you need a hand.
JackkTheMackk 01-20-2021 09:34 AM
Carrera tensioners in, valves all adjusted, and finally got the valve covers on. Tossed the fan and shroud on top just to see how it will look.
Up next is trimming the getty RSR shroud to fit. It needs a bit of love.
http://forums.pelicanparts.com/uploa...1611167488.jpg
http://forums.pelicanparts.com/uploa...1611167510.jpg
JackkTheMackk 02-12-2021 05:46 PM
Never thought it would take 10 hours to fit a fan shroud but here we are. Glad thats finally over.
Ditched my stock crank pulley since I deleted the AC anyway. Shaved a pound there and finally got the flywheel and pressure plate on. Shaved a decent bit of weight there also..
I have to trade out my intake manifolds and PMO since they measure 37.5mm and my heads are are 40.5mm and then I can toss on the carbs, JBR dizzy, and get working on the wiring! Slowly chipping away at this since work has been up like crazy. Hoping for end of March to have it back in the car.
http://forums.pelicanparts.com/uploa...1613184051.jpghttp://forums.pelicanparts.com/uploa...1613184051.jpg
http://forums.pelicanparts.com/uploa...1613184051.jpghttp://forums.pelicanparts.com/uploa...1613184051.JPG
faapgar 02-13-2021 04:28 AM
G-Wagon
Love your G-Wagon.5-speed is nice.I had a 97 G300TD and a G320 gas for 12 years when I was living in Costa Rica.Both had Cayenne wheels as they bolt on.Porsche car tax pales as compared to G-Wagon tax for parts.Enjoy.Fred
Harpo 02-13-2021 12:37 PM
This is what I'm using for my fuel filter
ID F750 Fuel Filter - Injector Dynamics
Harpo 02-14-2021 01:12 PM
Why JBR straight cut I/S gears? Why not Pauter?
faapgar 02-14-2021 04:08 PM
fitting the cool shroud
It is amazing the time it takes to fit one.You have to be almost have to be a macochistic personality to get it done.Ciao
JackkTheMackk 02-14-2021 06:01 PM
A very experienced engine builder who has been giving me a lot of advice steered me away from the pauter gears. He sent me photos of 3 gears sets with failures that he’s seen. These are also a tiny bit quieter than pauter because of the way they’re cut or finished, i can’t remember which.
JackkTheMackk 02-14-2021 06:02 PM
Exactly. Honestly when i bought it i just thought you throw them on. I had no idea it was this involved but no turning back now.
winders 02-14-2021 06:14 PM
Great part! I love mine!!
