Dont trust the dimensions on tires guys!! Look at this pics..
I went for picking up my wheels with new tires on yesterday, this year I choose to have a cheaper tire because there be no driving on tracks with this wheels.
Anyway I ordered a couple of Falken FK-451 in the dimension 255/35/18. It shows up that thoose tires is much smaller then my Yokohama in the same dimension was.?? Damn it!! Not a chance I agree with that, have any of you some explanation for me how it could be like this?? "The wheels are 10" wide" /Jocke
Jocke Andersson Reach me on ICQ - 317860713 Porsche 930 -77 SOLD Modified, one of a kind in Sweden. Check out my car @: http://members.cardomain.com/jocke |
Guest
Posts: n/a
I have heard of this before. 2 tires can have different tread width in spite of both being for example 255/35x18 tires. This, I'm told, is caused by a different construction in the "karkasse" (sorry for the danish word - have no dictionary here).
Insert Tag Line HERE.....
All of the 'new design' tires have that rim guard bead on the outer lip now, but Mikkel is right, although it seems all 285 width tires should be the same they arent.
Marc |
Platinum Member
The Falken is mounted, pumped with air, and has fresh tread. The other is worn & flat. I' bet its less of a difference unmounted.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
The Unsettler
It is actually fairly common for tires with the same spec to be slightly different sizes.
I always try and find the spec sheet on the manufacturers website to get the true measurements. There are enough minor differences to make a big difference in overall appearence. You also need to check the rolling diameter as it can slightly affect your speedo. Scott
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
All tires are different. If you go to the bridgestone site and look at the measurements for a 225 50 16 in RE 730 and S-03 the tread width is from memory about 1/2" wider on the S-03. I think in that case it's so the S-03 consistently outperforms its little brother. When going between brands it is likely to be even more skewed.
Guest
Posts: n/a
This could be the reason why some tires rub and others don't on the same car. My 245/40x17 Dunlop SP9000 *just* fit, but if I replace them with some other brand that has a wider cunstruction I'll probably get problems with rubbing.
Hard to se on this pic, but I think the difference are huge. (this pic are with Yokohama) /J
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
Irrationally exuberant
Bridgestone S-03 specs
Speaking of specs. You can't even go by the specs for different sizes in the same model and brand of tire. The specs for the Bridgeston S-03 245/45x16 list treadwidth as 9.1". When measured they are closer to 8.5". When mounted they are almost the same treadwidth as 225/5x16.
-Chris Bridgestone S-03 specs |
Jocke, that car is LOW. I'm suprised you can do anything but drive in a straight line
So you guys think itīs low?
No problem at all driving round the tracks
"hard as hell" /J
Just a note. The 'shoulders' of the tyres are different. Some have 'squareer' shoulders giving wider tread patch but 'edgier' on the limit characteristics. The 'rounded' shoulders are slightly narrower but will be more progressive...at least that's what my shop has advised me on different tyre types and makes.
Share with me. Teach me something I didn't know. Make me think. But don't make me a bit player in your passion play of egotism. Dueller. 13/03/09 |
Jocke,
I know you've been asked this before but what suspension are you running - all the details please. Thanks, Mark
'87 911 3.2ltr Cab. ROW (sold )'90 964 3.8 ltr C4 Coupe (P-Dealer built, track prep'd, sold ) )OMYG..I'm Porscheless |
Crotchety Old Bastard
Yokohamas run bigger (wider) than most other brands.
When the Pirellis wore out on the posermobile they were replaced with AVS Intermediates. I had to re-space the wheels due to the AVS tires being 3/4" wider than the others. (345/35-15).
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Sorry to say I dont have any spec or details on it. The suspension was already on the car when I bought it, but the old recipts shows that itīs RUF original, thats all I now... /J
