Hi,
The driver side door handle is not really working as it should.. I locked the door using the key then if I pull 5-10 times the door handle, the lock will go out of it's locked position and the door will actually open!! Anyone one knows what can be wrong ? Thank a lot! -J
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde Last edited by Oracle; 06-28-2003 at 05:52 AM.. |
Sounds like something might be loose in there. Take it apart and have a look
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Hi,
This happend to me a little while ago. I had leaking door rubbers which caused water to go down into the door. The whole lock mechanism was rusted which caused it to stop working. Ended up replacing the entire lock (had the shop do it...major $$$$). Might help to get the lock out and clean it very well.
-------------- '88 911 Carrera |
