How do I remove the retaining clip holding the break line?
It looks like to remove the calipers I have to disconnect the brake lines at the retaining clip. If this is the case I would need to bleed the brakes right? According to the 101 projects book it doesn't seem like this should be the case.
It looks to me as if the retainer is welded to the shock and the soft line and the hard line are connected to each other through a hole at that point.
What is the trick?
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 04-12-2003, 09:03 AM
RETIRED
Joe Bob's Avatar
The way "I" do it....hit it with some lubricant and grab the top of it with needle nosed pliers or vise grips....yank up, DO not bang hand when it releases suddenly.
2012 ML350 3.0 Turbo Diesel
Old 04-12-2003, 09:06 AM
it pulls up? ahhhhhhhhh... I couldn't see under there
Thank you Mike!
1979 911 SC Targa
Old 04-12-2003, 09:11 AM
Some years are removeable some are not. Mine can't be done without opening the brakes.
Old 04-12-2003, 09:23 AM
I don't think mine can either. There is no slot underneath the clip. It swivels on the axis a little bit, but not enough to matter. I have a 79. So is the verdict that I have to bleed the breaks? Its not a problem. I just bought 2 cans of break fluid with my pads and bearings.
Is there any other little tricks I should know? I wish my computer was in the garage!
1979 911 SC Targa
Old 04-12-2003, 09:33 AM
RETIRED
Joe Bob's Avatar
Mine's an 83....it has a clip that has notch in it.....
Old 04-12-2003, 09:39 AM
no notch on the 79. Hell! I'm gonna take my top off and go for a ride!
I can work on it when it isn't so beautiful outside...
1979 911 SC Targa
Old 04-12-2003, 10:04 AM
RETIRED
Joe Bob's Avatar
This is what it looks like....
Old 04-12-2003, 10:07 AM
I took a picture of mine too but I can't get it to upload now. Must be my conection speed. I am just a caveman with dialup and a 79 911.
Mike, You didn't take your wheel off to get to the clip for the picture did you? lol...
You are a motivated man!
Hey? how do I become a scwdp grunt anyway? Do I have to sabatoge a carrerror?
1979 911 SC Targa
Old 04-12-2003, 10:24 AM
RETIRED
Joe Bob's Avatar
You can become an honorary member by asserting that you should have bought an SC....and will do so, next time.....
That pic was from a spare I had lying around. It might not be off of a Porsche, but maybe the Chevy. But that what they should look like, or close.
Old 04-12-2003, 10:36 AM
Early_S_Man's Avatar
Porsche Crest
Definitely not a VW/Mercedes/Porsche Ate clip ...
Those flat clips do come off easily, but the upper pic is not the 'quick release' variety! Line must be disassembled to get the 'U' type retainer loose from the bracket/tab ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-12-2003, 12:28 PM
OK... so I have resolved that problem... Next issue in another post. I removed the caliper and the brake fluid has escaped...
1979 911 SC Targa
Old 04-12-2003, 02:40 PM
brittbolen's Avatar
just for the archives...
my 1970 911E has a fixed clip and to remove the caliper I had to disconnect the hard line from the rubber line at the strut before I could remove the front calipers
-- Britt
Old 06-29-2003, 07:19 PM
My 85 has the spilt clip....on some cars it's located so it pulls "out"..some "up"...I guess it depends how it's installed.
BTW...I found the same set up on my friend's 71 914....why would intervening years for 911's be different?
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-30-2003, 04:41 AM
My 79 is split in the back and solid in the front... I guess it was a gradual process of evolution...lol
1979 911 SC Targa
Old 06-30-2003, 05:02 AM
