LinkBack | Thread Tools | Rate Thread |
It's a shame the late model sport seats aren't full manual, they'd really be perfect then. Random thought: one power sport seat weighs more than four Fuchs Evolution 9x16s!!! ![]() And yeah, selling the sport seats would largely defray the cost of the Pole Positions.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
I'd do this
![]() Mine is similar ![]()
Frank - the seats look great.
I also used Bill's threads to help with my install. I went with Cobra Suzuka seats, which I have never seen in an air-cooled 911. The install was a challenge as the thigh bolster on those seats is much higher than most. You can get all the hardware on McMaster - https://www.mcmaster.com/ |
At least on the Speedsters, the receptacle went outside the seat and not through the slot. The length of yours looks about right as they should come up to about the edge of the seat.
They made several versions of it depending on which seat it came with. Those look like they were original sport seat receptacles. Quote:
KYUKYU3
Nice! I also followed bills seat diy and they are spot on. I ended up with planted sides for mine and they worked great to get the seat as low as possible. I remember the other brackets were slightly higher.
As for that 964seat belt tunnel bracket, if memory serves me correctly, that extra 3mm space was needed for the slider U handle to "disengage" the sliders. At first I had 6 point harness and skipped using that tunnel bracket and couldn't get the sliders to move once in the car. It was not until I put some thick grade 8 washers thst were about the thickness of the tunnel bracket between the sliders and the sides did the sliders work correctly with the slider U handle. Sent from my Pixel 3 XL using Tapatalk Last edited by samurai_k; 11-15-2020 at 12:04 AM.. |
Thanks for the responses gents!
Jae Lee suggested I try using the rear seat belt receptacle on for size. That could be an interesting option. Quote:
I may just go with the standard 964 inboard seatbelt anchor install for now, until I can get my hands on some of the other mounts for A/B/C/etc testing. Although, the two M8 holes in the 964 inboard seatbelt anchor do not line up with the M8 & M6 holes in the aluminum side brackets / steel seat rails, so you either have to drill the anchor or the bracket/rail to get it to work. Ugh.
Part of my point is that it should probably be that long as you want it to be close to the edge of the seat like they designed it which is probably to have the correct geometry?? Not sure.
Anyway, the non sport seat option is shorter. Below is a picture of how that factory wanted them positioned. Quote:
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 11-15-2020 at 09:02 AM.. |
inside or out depends on the angle of the connection, the higher the bolster the less favorable that angle becomes, you want the angle of the connection to be 0 Another point is that not all receptacles are compatible, I tried some from a 997 that were incompatible w/ my 993 ones, front and rear on a 993 are compatible
Are you politely saying a lard ass? Just kidding. You are correct as that announcement is made before every takeoff- keep your belt low and tight about you. The factory had another issue to deal with on the 964's and that was the console and needing to get the receptacle up where you can reach it. Even being less than "Dumbo" sized, it would be physically impossible for me to get in the factory Speedster seat with the receptacle protruding through the slot which is I guess why Recaro came out with the widebody version.
I may source a spare set of rear receptacle assemblies and, if need be, have HMS Motorsport* sew custom length webbing between the mounting eye and the actual receptacle / release itself. The custom length and the non-rigid webbing should allow me to place the receptacle / release anywhere I want. Hmmmm, I'm liking the sound of that. *HMS Motorsport has made custom length Schroth harness lap belts for me in the past.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 11-15-2020 at 12:57 PM.. |
KYUKYU3
So I checked my seats today and noticed the planted sides stick over the width of the recaro sliders so it looks like the need for the 3mm washers between the slider and sides was specific using the planted sides.
I hear you about the tunnel side buckles. I tried using the long sport seat buckles and they were sort of a pain to be outside the bucket. I am interested how your project goes with the rear buckles. I too got some rear ones and like you said eventually cut the plastic sheathing and see if I can put them through the factory lap belt cut outs. ![]() Sent from my Pixel 3 XL using Tapatalk |
6 cylinder symphony
Those seats are sex. I love them. I have factory sport seats in both my cars, but if I ever decide to change, this is what I am doing.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
I have, no, wait... *had* them in both of my cars too! Then the sex happened. The '88 491 cab is 60k miles, original paint, yadda, yadda, yadda, so I leave it alone mostly (Web 20/21 cams by 2nd owner, stealth pre-muffler, Steve Wong tune, Solid State DME relay, Classic White gauge LEDs, manual top conversion, Jae Lee sorted ERP / Elephant / Bilstein suspension). It pulls and drives like no stock looking G Body cab that I've encountered. https://amoroso.smugmug.com/1988-Porsche-911-M491-M470-Poi/1988-Porsche-911-M491-M470 The '87 coupe is a repaint, 105k miles, so it gets more overtly optimized. Most of the mods are subtle / invisible to 99% of folks out there, so the Pole Positions will be the most overt departure. She's down to 2,856 lbs now and I'd LOVE to get her to 2,775 lbs., But that's not in the cards short of a sunroof delete AND Classic Retrofit AC system. Alas, neither are in the cards.
In such a situation I'd imagine one cannot set the tunnel side belt though side opening if tunnel mounted. Inside belt would have to be rail slide/side bracket mounted or it would be sliding in and out of the side hole with the sliding movement of the seat. If anything I have wrote based on what my understanding of posts is incorrect, please feel free to correct. Also posting this diagram as to remind myself what a bolster is. ![]()
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 11-19-2020 at 04:53 AM.. |
The seats are in. I haven't finalized the mounting-up as of yet, but here's what they look like at the moment...
Also, I have a rear mat being made from matching Pepita that will sit atop the rear seatbacks (when they're folded down) to carry the theme to the rear. The OE sport seat seatbelt receptacle is too long. Per Jae and Bill's suggestions, I went ahead and used the OE rear receptacle and it works. It's not optimal, but it is serviceable. I can route the seatbelt buckle through the inboard bolster opening and engage the receptacle, but it is awkward / a two handed operation. Then, unfastening the belt is tricky too based on where this places the release. You can also route the belt / buckle over the inner bolster to engage the receptacle and this method is quicker / less awkward. I have a message out to HMS Motorsport to see if they'll shorten the OE rear receptacle webbing for me. This custom solution may prove the most efficacious. ![]() ![]() ![]() Here you can see the rear receptacle mounted to the 964 Carrera RS anchor (which is itself sandwiched between the aluminum side bracket and the steel slider in this pic). In addition to shortening the webbing on the rear receptacle, I would like to find the proper combination of spring / wavy washers and mounting bolts such that the entire receptacle will remain upright (like the factory front receptacles)... ![]()
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 11-22-2020 at 09:31 PM.. |
what company did you buy the Recaro's from...????
I can't find someone who I can get any straight answers from help , thanks anthony |
You can try...
Christopher "Chops" Smith chris@g-werke.com Griffin Motorwerke, Inc. (510) 524-7447 www.g-werke.com ... domestically. I went with Gert at Carnewal - Car parts and accesories though as he was the only one that had any answers back in April when I originally inquired.
Ok, I chatted with HMS Motorsport and they won't do custom length webbing on anything that's not a Scroth piece. Ugh. I get it tho.
So, I feel as if I either want the inboard seatbelt receptacle assembly (receptacle + webbing + mounting tab) 1) a bit shorter, such that the seatbelt buckle engages the receptacle below the side bolster opening (regardless of whether I route the belt over or through the side bolster), or 2) a bit longer, such that the receptacle is properly placed inside the side bolster and the sestbelt is always routed to the inside. Any suggestions? Also, per the below inboard / through the bolster routing, the release button being situated on top of the receptacle itself is problematic (with the receptacle assembly at its current length). Not sure what to do about that as it will depend on where the receptacle itself eventually ends up. ![]() ![]() ![]() ![]()
You should be able to get an upholstery shop to shorten and stitch it up for you.
