alternator
need to replace alternator in my 71 911
number of reviews say this doesn't fit,
https://www.pelicanparts.com/More_Info/AL9341X.htm?pn=AL-9341-X-INT&SVSVSI=5867&DID=13355
but is listed to fit
is pelican wrong about this?
gary burch
71 911
Old 04-14-2021, 06:44 AM
You can opt to let rebuild yours
Is much cheaper
I have a 911 1970 and viewing the picture it seems correct
Old 04-14-2021, 01:07 PM
Is much cheaper
This. And likely a better alternator than many available units. And you know it will fit.
Find a lost rebuild shop. You will be better off.
Old 04-15-2021, 10:57 AM
Yes, that's a 70A alt. Most '71s used a 30A, but some may have a 55A. The 70A requires a different fan housing.
Dave
Old 04-15-2021, 02:00 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Check if the VR (voltage regulator) is built into the Alt or by the rear fuse box. Was separate on my 73 and integrated into the Alt on my 89.
Replaced mine a couple weeks ago. Remanufactured Bosch Alt from Advanced Auto. Fit and works perfectly. Prob better than the Velaro Alt that was stock. $200. Looks new.
Chris
Old 04-15-2021, 02:19 PM
Chris
The only Bosch alt that was used on pre 1990 Porsches was before 1975.
All the alternators available now are Valeo types up to the 964 Bosch.
Because the box indicates Bosch, doesn't mean that it's a Bosch design.
Dave
Old 04-15-2021, 02:39 PM
Is much cheaper
Old 04-15-2021, 02:42 PM
Is much cheaper
As can be seen on the plate, it's a Bosch 55A.
Dave
Old 04-15-2021, 02:49 PM
going to try the rebuild route
thanks
gary burch
71 911
Old 04-15-2021, 04:51 PM
cmcfaul's Avatar
Dave,
It says Bosch right on the Alternator and it fits and works perfectly. Installed it a couple weeks ago on my 89 Carrera.
No way would Advanced Auto put a Velaro alternator in a Bosch box or change labels.
Chris
Old 04-16-2021, 09:56 AM
Dave,
Chris
It's a Valeo Alternator! The same one my '88 911 had as original equipment.
Again, Bosch NEVER made an alternator for a 911 3.2 ('84-'89).
That Valeo, "Bosch Rebuilt", is even less reliable than the original Valeo. Because instead of French Valeo regulator, it uses a junk China regulator.
Look closely, it's a reman junk!
Dave
Old 04-16-2021, 10:26 AM
We have sold over 40 of these Bosch remanufactured units in the last year with only 1 returned. Being its a remanned unit theres always an off chance of QC issues but this appears to be the correct unit for your model and year.
Old 04-16-2021, 10:27 AM
cmcfaul's Avatar
Its Bosch. Label, warrante, Box, documentation and all. Can't convince me otherwise.
Old 04-16-2021, 06:28 PM
Auto Air Marine Electric in El Cajon can rebuild it. Talk to Scott
Old 04-16-2021, 06:54 PM
And my '88 911 3.2 is now a '88 911 Turbo, since I installed a turbo sticker, right?
Some still believe the earth is flat and the sun revolves around it!
Dave
Old 04-16-2021, 07:40 PM
Originally Posted by Gianni at Pelican Parts View Post
We have sold over 40 of these Bosch remanufactured units in the last year with only 1 returned. Being its a remanned unit theres always an off chance of QC issues but this APPEARS to be the correct unit for your model and year.
I would feel much better about it if you said it IS the correct unit for my car and year
gary burch
71 911
Old 04-17-2021, 06:45 AM
If your Porsche is a 911 3.2 ('84 - '89), it's the correct alternator (a 90 amp Valeo).
Porsche also used a Valeo as an OEM alt (75A) in the '82/'83 911SC, not a Bosch.
Dave
Old 04-17-2021, 08:02 AM
1971 911
gary burch
71 911
Old 04-17-2021, 12:23 PM
1971 911
Read post #4.
Dave
Old 04-17-2021, 07:45 PM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
I installed one of these high output alternators in my 88. With lots of modern add-ons to include upgraded A/C (Griffith's system), sterol, USB plug-ins, radar detectors, etc, my volts would run in the low 13s and dip into the high 12s when all the/ a/c fans and condenser electric fans would come on. After installing this alternator, I never see lower than the high 13s.
https://www.classicretrofit.com/collections/upgraded-alternators/products/porsche-911-high-output-150a-alternator
Good luck.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002
1988 911 Cab - 5MT - Purchased Used in 2005
2008 Cayman - 5MT - Purchased New in 2007
2014 911/50 - #1173 - 7MT - Purchased CPO in 2014
2019 Macan S - 7PDK - Euro Delivery/New in July 2019
Old 04-18-2021, 05:43 AM
