81 911SC roll bar drop link bushing pulling out.
Hi all,
This keeps happening - one side of the rear anti-roll bar (sway bar for you guys) pulls the droplink body off the top rubber bush.
The top bush stays bolted to the beam, the bottom bush stays bolted to the roll bar with the metal link attached.
81 911SC on Bilstein HD Nurburgring dampers.
I had the car set-up by a known east coast shop a few years ago. They corner weighted and aligned it.
Up to that point the car was riding the bump stops all the time. Terrible ride and dynamics.
The shop cut the bump spots as part of the corner weighting. It does sit low, visually. But no rubbing or bottoming out.
Is the droplink issue a consequence of the lower ride height? You can see the alignment of the bushes isn't quite right when static.
Old 05-27-2020, 09:05 AM
I have the same issue, after 2 seasons on an Elephant Racing suspension refresh. My wrench says it’s either a bent banana arm (no idea if it’s the case) or a bent spring plate (wrench says one looks to be a bit bent). I’ve put a new link in for the time being; it’s exhibiting a lot of preload to get the link on. Wrench suggested trying adjustable links, which I may.
Old 05-27-2020, 01:34 PM
Hi - I would have thought that a bent arm would show when the alignment was set and a bent plate you would be able to spot by eye? Also while its the same side pulling out, the other side is on the cusp of doing it, suggesting that the side loading is similar on both ends of the bar.
This is my second set of droplinks, I will investigate the adjustable ones.
Thanks.
Old 05-28-2020, 12:32 AM
just a thought without looking at it but can you add washers behind the top mount to move it forward more inline with the bar? Or perhaps a large washer on the outside to help retain it. I would say its more likely a bent swaybar causing misalignment
Old 05-28-2020, 06:32 AM
Flojo's Avatar
it is missing the big washer to prevent this!
always mount droplinks with wide diameter washer between link rubber and nut
or get the stainless steel ball-joint version
https://partworks.de/partworks-de-Porsche-968-Koppelstangen-fuer-Porsche-924-944-968-Stabilisator-Hinterachse-UNIBALL.html
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 05-28-2020, 06:39 AM
Checking the PET the drop links are different for each side so are they mounted on the correct side of the car?
Old 05-28-2020, 07:18 AM
Ahha! That would make sense. Replacements didn't come with these!
Many thanks.
Old 05-28-2020, 07:50 AM
Will check that as well!
faverymi's Avatar
If any part is bent it would not corner balance period. It takes experience to see this.
Then you have to investigate what part is bent. It could be the chassis also.
That was the problem in one of my cars. Trail and error....
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 05-28-2020, 11:12 AM
Red Line Service
Marc Bixen's Avatar
It looks like you have the Lemfoerder drop link:https://www.pelicanparts.com/catalog/SuperCat/0801/POR_0801_SUSSHK_pg9.htm#item30
These are junk, the bushings are not captured as the original.
After just bashing Uro parts on another thread, I will recommend their part here!
Look at this drop link and how the bushing is "captured".
Just like the factory unit.
Our host shouldn't even sell the Lemfoerder.
As others have said, a large washer will help, but I'd recommend the Uro or the O.E.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 05-28-2020, 06:21 PM
Yes - I noticed that as well after looking at the link!
Think I might just stump for the solid / adjustable ones.....
Old 05-29-2020, 02:48 AM
Pelican Parts Vendor
UROParts's Avatar
Look at this drop link and how the bushing is "captured". Just like the factory unit.
Thanks for the update Marc! We made a running change to the link eyelet angle during the Summer of 2019, glad to hear we've got them dialed.
Pelican offers them here:
LH: https://www.pelicanparts.com/More_Info/93033307101.htm?pn=930-333-071-01-M253&SVSVSI=0801&DID=15390
RH: https://www.pelicanparts.com/More_Info/93033307201.htm?pn=930-333-072-01-M253&SVSVSI=0801&DID=15066
If anyone had issues with our pre-2019 links being misaligned, please contact us with your purchase details and we'll get you a new set under warranty.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2
Old 05-29-2020, 09:22 AM
