Stack 430 Tachometer with Bosch CDI 6 pin
Hello
Is it possible to use Stack 430 as tachometer with a 6 pin CDI box ( Bosch 004) ?
I have wired TD pin directly to orange Stack wire but the needle didn't move at all. The orginal tachometer was useable without any problem.
Thanks for your help
Old 11-03-2014, 11:41 AM
porschetub's Avatar
Originally Posted by manu72S View Post
Hello
Have you a selector on the back of the tacho for 4,6,8 cyl options,is that set right?if it is you will then most likely need to buy a tach adaptor,our host sells one.
My understanding is the factory VDO tachs are matched to the engine/ignition of that year car,most modern tachs have that adaption in the selector,don't know about your brand however.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 11-05-2014, 09:24 AM
Hi
Thanks for your reply
No adapter
My tachometer ( 911 641 301 03) is totally functional with the Bosch 6 pin CDI ( 0 227 300 004). But when I put my Stack there is no needle movement.
I can say : my Stack tachometer is functional with Bosch 3 pin CDI ( 0 227 200 001 ) too.
Old 11-06-2014, 01:13 AM
Lifts an old throad.....
I have the same problem..I have a Stack 430 and 2x6 pins boxes.With the black/Purple to the Orange lead it dosent work.Also try,by suggestion to put aST697 speed pulse sensor to the coil,but I think I "burn" it...So the Q is.....Anybody using Stack on a Porsche.How do you connect it..?
Old 06-09-2020, 03:41 AM
Hi
3 pins and 8 pins boxes there is no problem with Stack
For 6 pins you need to modify it ( diode D8)
Manu
Old 06-09-2020, 10:32 PM
Thanks for answer.Did you mean to modify the CDI-box....?
Old 06-10-2020, 06:35 AM
Jonny H's Avatar
Hi
No adapter
3 pin CDI boxes do not have a tacho drive. On 69/70 cars the tacho is driven from the coil voltage (400V). Up to the last 3 pin cars (1976) the tacho is driven from the points.
www.classicretrofit.com
Old 06-10-2020, 12:58 PM
AndrewCologne's Avatar
Seems that Stack needs a 0v/12v switching pulse width signal as stated by Gerberding:
https://www.911-hkz.de/TDSignal.htm
Furter below you can see the Stack regarding part.
Its german but todays google translator output is quite ok.
BR
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 06-11-2020, 03:47 PM
..Thanks..
Old 06-14-2020, 08:34 AM
